1978 - 1996 Big Bronco
Which load range for Goodyear tires?
Old Jan 23, 2007 | 10:21 AM
BHOFFMAN's Avatar
BHOFFMAN
Let me start off and say I have a 1996 Bronco XLT with 16" Weld Racing rims. My current tires are Goodyear AT/S 265-75-R16 in load range D. They no longer make the AT/S tire and have replaced the model with "Silent Armor" models. I am extremely happy with the AT/S's, (so don't suggest a different brand.) My issue is they no longer make load range "D", they make these tires in C or E. Tire Rack tells me the ride is decreased about 20% with E vs. C range tires. Which should I buy? It is a Bronco, not a F250, so it is not like I am hauling bricks around in the bed. I use it to pull a boat at times, but I cannot think the tongue weight is more than 500 lbs. What is your experience? This in mostly an on-road vehicle. Occasional dirt/snow driver, but no hard core wheeling.
Old Jan 23, 2007 | 02:28 PM
wileec's Avatar
wileec
Like you said you are not moving a ton of bricks I would go for the ride quality and choose the Cs. More than enough load range for a Bronco.
Old Jan 23, 2007 | 04:58 PM
aurgathor's Avatar
aurgathor
You don't even need a D. Stock was XL (44 PSI), BTW, so C should be plenty.
Old Jan 23, 2007 | 09:10 PM
rollerstud98's Avatar
rollerstud98
i like the ride with my E tires on at about 88 psi on my 1-ton, but i just like it rough like that
Old Jan 23, 2007 | 09:13 PM
dwoodler's Avatar
dwoodler
I run the MTR's at 35 psi and howl down the highway and the ride is good - not soft like a car but not a lumber wagon either.
Old Jan 24, 2007 | 10:02 AM
adelyser's Avatar
adelyser
I've got C-range tires on mine, and never have any problems. I haul my horse trailer locally, which weighs right around 7500lbs fully loaded, and the tires have never had any problems.
96mark8
Sep 14, 2014 11:41 AM
74baja
Jun 20, 2009 03:05 PM
guthrie&co
25
Mar 5, 2009 08:34 AM
cterrysgd
Dec 22, 2005 04:24 PM
jhl385
Jan 1, 2005 03:14 PM
