Motor dies
Old Jan 23, 2007 | 07:38 AM
ruger761's Avatar
ruger761
Motor dies
When under a hard throttle, in the mud normally, the truck will die if i let off the throttle very fast. Starts right back up and runs fine. What would cause this or is it a safty feature or something? I have seen pulling trucks do it to.
Old Jan 23, 2007 | 08:50 AM
tjbeggs's Avatar
tjbeggs
could be a cam sensor could also be bare wire somewhere that water is getting to.
Old Jan 23, 2007 | 09:42 AM
ruger761's Avatar
ruger761
Is there a way to check the CPM? I dont get that much water up to the motor.
Old Jan 23, 2007 | 02:51 PM
tjbeggs's Avatar
tjbeggs
there isn't a way to test the CPS other than if it throws a code. but it is a common failure item so if you don't have a new one on hand i would buy one and try it. if its doesn't work you will have a spare one in your glove box like most of us here do.
Old Jan 23, 2007 | 02:58 PM
ruger761's Avatar
ruger761
Ok thanks I will give that a try
