boost cooler
Old Jan 23, 2007 | 04:07 AM
Bin Strokin's Avatar
Bin Strokin
boost cooler
has anyone made a home made boost cooler? it seems pretty easy to make i was just curious if anyone had some tips.
Old Jan 23, 2007 | 05:43 AM
ryaneverk2's Avatar
ryaneverk2
Are you referring to an intercooler, or charge air cooler?
Old Jan 23, 2007 | 10:18 AM
CSIPSD's Avatar
CSIPSD
or water injection?
Old Jan 23, 2007 | 12:40 PM
Bin Strokin
water/methanol injection
Old Jan 23, 2007 | 02:14 PM
bigtorque's Avatar
bigtorque
if you look at the parts, you would think it would be simpe to make, just where to get a water pump with that kind of preassure 150 to 180 psi. and how will it adjust it self like the snow performance one,
Stage 1 Diesel Boost Cooler™
This kit progressively injects more or less water-methanol, according to manifold boost pressure. The system is applicable for turbo diesels making up to 25psi of boost pressure. It has two dials to set the start and full points to tailor the delivery to your engines needs. Progressively injecting according to boost pressure allows for the most power over the widest range of rpms.
Old Jan 23, 2007 | 03:04 PM
CSIPSD's Avatar
CSIPSD
I have a snows kit and I recomend the cooling mist kit... What does that tell you...
www.coolingmist.com
Old Jan 23, 2007 | 08:58 PM
bigtorque's Avatar
bigtorque
CSI, where can we look at the cooling mist kit.............
Old Jan 23, 2007 | 10:22 PM
CSIPSD's Avatar
CSIPSD
http://www.coolingmist.com/pagedispl...ure_key=diesel
Clicky linky
Old Jan 24, 2007 | 12:15 AM
bigtorque's Avatar
bigtorque
ummm,,,,,,,,where my credit card at...........
im liking that one. though how long will 1.5 gallons last on a good long pull.
Old Jan 24, 2007 | 10:00 AM
CSIPSD's Avatar
CSIPSD
You can go to a farm store and get a big spraying tank, or I think they sell a 8 gal tank too. I have a 8 gal tank in the tool box and its good for about 400 miles...
