Sponsored by: Innova
radio removal
Old Jan 22, 2007 | 08:51 PM
2dxtreme's Avatar
2dxtreme
radio removal
how do i remove the radio in my 1987 f250? i want to put a aftermarket cd player in. i just don't know how the stocker comes out
Old Jan 24, 2007 | 06:30 AM
ubereal2's Avatar
ubereal2
That shouldn't have the locking stereo. If therer are four small holes in front of the stereo (two on each side) then you will need the tool to unlock it. Simply insert tool into holes until it locks into stereo and pull out.
If it dosen't have the locking stereo, remove the dash cover around stereo by removing any phillips screws that you may see, then prying around the edges to unclip the dash trim.
You're factory stereo should have four screws, or small bolts to unscrew to remove.
Bob
Old Jan 24, 2007 | 06:54 AM
2dxtreme's Avatar
2dxtreme
ok thank you it doesn't have the 4 little ford holes. i'll try that dash ring thanks for the response
Old Jan 24, 2007 | 10:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
using a small screwdriver, pry the dash cover off of the radio/heater section. once you have that off, you will see 4 screws holding the radio in, 2 on each side.
Old Jan 24, 2007 | 06:04 PM
2dxtreme's Avatar
2dxtreme
do u know what the colors are for the back of the radio if i want to add a aftermarket radio?
acc
constant
left speaker
right speaker
ground
Old Jan 24, 2007 | 07:27 PM
FTE Trigger's Avatar
FTE Trigger
To make it easier, you should get the appropriate wiring harness (Metra or Scosche brands are what "I" use) A good Matching harness will already be labelled on the wires or have a cut-sheet on the package.
Old Jan 25, 2007 | 06:30 AM
tjc transport
i ain't rite
this site has most of the radio wiring color codes
http://www.installdr.com/
Old Jan 25, 2007 | 06:47 AM
2dxtreme's Avatar
2dxtreme
awesome thanks for the link very helpful
Old Jan 25, 2007 | 01:17 PM
tjc transport
i ain't rite
yes it is. i keep it bookmarked in favorite places so it can be easily found. it seems like at least once a week i have someone coming over to get a new radio installed, and that sit has saved me a lot of time.
badfl97
2004 - 2008 F150
Oct 18, 2009 01:12 PM
PSWP
2004 - 2008 F150
Jun 21, 2008 05:24 PM
Boonebird
20
Apr 2, 2008 07:08 PM
berganbart
Nov 28, 2007 12:15 AM
PickSty
Apr 16, 2004 10:07 PM
