Installing a NAV Unit - Need Wiring Help!!
Another wire needs to tap into the + terminal for the reverse gear lamp that is only fed when the trans in in reverse. How do I find this wire?
Finally, where is a point on the firewall where I can run a hot off my battery for my Amp?
Hopefully with a little help, I can complete this install on my own. Thanks!
Reverse Light= Black/pink at the fuse box
Right below where the bundle under the hood, on the drivers side, that has the 4 pass-through wires is, there's a pretty good sized rubber plug that looks like a diamond laying on it's side, punch through that to run the +12V for the amp.
