2002 Tranny Problem
Old Jan 22, 2007 | 06:21 PM
Woodys Janitor's Avatar
Woodys Janitor
2002 Tranny Problem
I have had the Ford Dealership try to fix a leaking problem with no success. They have replaced(they claim)seals, torque converter, and the latest; vent drain. Do you have any ideas what is going on? It leaves three spots of fluid on the drive-way or anywhere else I park it. It only has 73,000 miles of easy driving. It has NOT puled anything. Thanks
Old Jan 23, 2007 | 09:37 AM
pbjohns's Avatar
pbjohns
I know we are talking tranny, is the fluid oil, water, or what? Can you describe the color, or the feel of the drop's.
Old Jan 23, 2007 | 02:47 PM
Woodys Janitor
It's RED tranny fluid.
Old Jan 24, 2007 | 10:54 AM
pbjohns's Avatar
pbjohns
Is it possible for you to get under the truck and look for the leak yourself?
Old Jan 25, 2007 | 08:18 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I know ford had some problems on a few mustangs where the case itself was leaking near the front transmission seal area. It wasn't cracked or anything, just excessively porous, allowing fluid to actually seep through the aluminum case. The only repair was to replace the transmission case.
I don't know if this is the case or not on your vehicle, but anything is possible.
And just for your information, transmission fluid leaks on these are extremely rare, so there's no "typical problem" on these to report.
I wish you the best of luck!
Old Feb 10, 2007 | 10:45 AM
Woodys Janitor
So far changing the vent drain has solved the problem. It's to bad they couldn't have figured that out a while ago.
Thanks for your replies!
