Sponsored by: Auxito
Axle Swaps???
Old Jan 22, 2007 | 04:22 PM
jimbo8's Avatar
jimbo8
Axle Swaps???
My 97' F150 4X4 has 3.55 gears and I would like to upgrade to 3.73's. Will axles from a newer truck bolt up? What if they're 9.25" vs. 8.8"? I have read that lower gearing really helps the 4.6 on the low end with out killing gas mileage, assuming you don't go too low. I'm not looking to get any radical improvements, just want to make the usual tasks (occasional load of lumber, pulling a camper 8 or 10 times a year) a little easier on the engine. What do you guys think?
Old Jan 22, 2007 | 04:25 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You would save a lot of time and money if you just get a new Ring and Pinion in the gear ratio you want.
Old Jan 22, 2007 | 04:27 PM
shanesF150's Avatar
shanesF150
are you running stock tires...
Old Jan 22, 2007 | 05:22 PM
jimbo8's Avatar
jimbo8
I'm running 265-70 16's. I found several stock 3.73 gear sets on ebay. But I've always heard that swapping gears required some special tools for setting backlash and other stuff, and that even with the right tools it was still pretty tricky. I'm pretty handy with anything mechanical, I've rebuilt engines in cars, atv's, etc. But I have absolutely no experience with diff's. Thats why I was looking at swapping out the whole thing.
Old Jan 22, 2007 | 06:23 PM
Ford Fx4's Avatar
Ford Fx4
I see that you have a 4x4, If you are changing gears to 3.73 from 3.55 you are going to need to change the front gears also to 3.73.
Old Jan 22, 2007 | 10:00 PM
jimbo8's Avatar
jimbo8
Yes, I had already figured on doing both diff's. If I just swap out the gears in them would I need more than just the ring and pinion sets. Will the clutch in my rear diff work with 3.73 gears?
Old Jan 22, 2007 | 10:49 PM
alberta46's Avatar
alberta46
If you decide to do it I would like to know if you want your old gears I am running 3.08 and would like to put 3.55 in I also have a 4x4. any help would be appreciated.
Old Jan 22, 2007 | 11:28 PM
NavyFlyer's Avatar
NavyFlyer
so how big of a job is it to swap out to the 3:73's?
Old Jan 22, 2007 | 11:31 PM
shanesF150's Avatar
shanesF150
i have naver done it...
find someone who will back you up and get them installed and make her it comes with a warrenty...
doing it your self can be done but i dont know how so i cant say lol
need the tools.. you need some weard tool to sence how much space thare is on the
gears or something and you need a press for Sureeee...
i have seen it started naver finshed...
Old Jan 23, 2007 | 07:24 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Its really not to bad of job once you have done it a couple of times. Except for the back lash... that is kinda tricky. Your best bet is to let sombody who knows what there doing to help you with it. Im sure that you can figure it out but alot of times when sombody who is new to it does it, you will have a humming noise especially when decelerating.
Old Jan 23, 2007 | 08:00 AM
NavyFlyer's Avatar
NavyFlyer
cool thanks
Old Jan 23, 2007 | 06:52 PM
Moore FOMOCO's Avatar
Moore FOMOCO
Hey NavyFlyer what squadron? Ex-VFA-86er '89-93, F/A-18C Lot 9's! Iraq the first time around.
justintyhme
Jul 29, 2014 06:12 AM
SZAlbNM
Sep 8, 2013 02:07 PM
icobod
16
Sep 21, 2011 05:40 PM
bsakal
Jan 13, 2007 01:10 PM
wmcl
Dec 31, 1999 09:45 AM
