Dead Battery
Old Jan 22, 2007 | 11:30 AM
grumman's Avatar
grumman
Dead Battery
I have a problem in which my battery is dead some time and it is not a bad battery. Since this problem has started some times when I turn the truck off my radio continues to play if I had it on, and requires me to turn the radio off. Other times when my truck and radio are off and I leave it and come back later the radio is on. I assuming that my dead battery is because the radio has been on and drained the battery. Seems like my problem is the rado or the ignition switch. Anyone had a similar problem?
Grumman
Old Jan 22, 2007 | 12:31 PM
87 XLT's Avatar
87 XLT
Might be a stuck accessory delay relay.
If you have a decent set of wiring diagrams they will tell you where the relay is located.
With the radio turned on, remove the relay. If it does'nt click when you remove it you need to replace it.
Old Jan 22, 2007 | 12:37 PM
grumman's Avatar
grumman
Thanks for the reply but, I don't have any wiring diagarms. I will look under the hood for a relay that might be labeled.
Old Jan 22, 2007 | 12:49 PM
jimdandy's Avatar
jimdandy
What year truck????????? jd
Old Jan 22, 2007 | 01:42 PM
aquanaut20's Avatar
aquanaut20
check that key is turning off all circuits
deshet1980
May 24, 2017 04:13 PM
Rottsailor
1997 - 2003 F150
Nov 25, 2014 10:25 PM
red dog
2004 - 2008 F150
May 18, 2014 06:39 AM
Demo-man
6.7L Power Stroke Diesel
Jan 14, 2014 08:58 AM
wtmac
Mar 31, 2004 04:30 PM
