If it is 2.25" pipe, duals would give you 7.05 square inches of pipe to flow through.
If it is 2.5" pipe, duals would give you 9.85 square inches of pipe to flow through.
A single 3" exhaust gives you 7.08 square inches of pipe to flow through.
So even if the stock pipes are 2.25" doing the duals is still the equivalent of putting a 3" system on....
Two pipes are more restictive than one, given the same cross-sectional area. This is related to the ratio of the cross-sectional area to the surface area of the pipe. Dual 2.25" pipes will not flow as well as a single 3".
Ken
I hadn't ever thought of that - but it makes sense. Greater surface area = more friction (i.e. resistance to flow) where the exhaust gas comes into contact with the inside surface area of the pipe(s).
However, the difference is going to be pretty small, since we're talking about a gas (rather than a liquid), and given that fact, I think it's still pretty safe to say that the difference is going to be minimal. The biggest issue is having enough volume/space for the escaping exhaust to have somewhere to go.
Pretty safe to say that the difference would definitely be small enough that two 2.5" pipes will flow better than a single 3"...
....Checkout the Auto jet 3" exhaust. Comes with a mandrel bent y pipe, and freeflow muffler. Around $300....
I've seen several references to that system, but so far no one has been able to show me a picture of the Y-pipe. That's the critical piece IMHO, since several companies all offer 3" systems - but every one I've seen has the same basic y-pipe design as the crappy-flowing stock piece.
Can the dual pipes off the headers be bigger than a 2.5"? What if both pipes were 3"?
If you can figure out a path to run duals down both sides of the underside of the truck, sure 3" would fit as easily as 2.5"...
Trouble is there isn't a pathway alongside the driver's side to run a pipe to the back. Too many things in the way (fuel tanks for one). You might be able to do it, but you're going to end up with your exhaust pipe running under the tanks and crossmember. The solution some have come up with is to run duals but run them both down the passenger side in the location of the original exhaust.
can't see how it would be possible to run two 3" pipes through there - especially in the area where it goes up & over the crossmember. My single 3" doesn't have all that much room to spare, and even dual 2.5" pipes will be a tight fit. Particularly in the area of the crossmember.
From what I've read, the headers are not worth the money. $500 for 5-8 HP...
Just curious where you read that number. Stans Headers claims up to 55 HP gains with their headers to dual 3" exhaust (not sure how they're doing that, but anyway). While that might be somewhat inflated, others around here have seen calculated gains more in the range of 30-40 HP...
What size is the stock exhaust on my 85 6.9? I had a local muffler shop run duals on my truck, although I don't remember the diameter. I remember it did wake the truck up though, can't give numbers, no use of nor money for a dyno check. It brings up another point though. Aren't diesels designed to run with some backpressure? I'm running what Walker called at the time a "turbo tube", which I am sorry to say I can't find anymore. They are very loud on my truck, but the sound is beautiful. I ride also, and I've been behind my truck going down the road before, and let's just say it's not a pleasant place to be on a motorcycle. Anyway, how much backpressure is needed, if any? Because there is very little to my mufflers, you can look right through them. Another exhaust thought, how about an "H" pipe in there somewhere? On the other hand, true dual exhaust gives the opportunity to the owner to diagnose which side of the motor could be having problems simply by the differences in smoke on the two sides. If you are sucking air on an injector for example?
That's the debatable part - either 2.25" or 2.5" - depending on who you talk to....
One on each side or both on the passenger side?
None - the less the better (unlike gassers). You want "see through" mufflers - like the glasspacks I suggested to chewyjackson, Cherry Bomb is my personal favorite...
The "H" would help balance it out, and even out the sound. In some applications it also helps with scavenging - though I can't say whether that this would be true of the IDIs or not. The point about isolation for purposes of diagnostis is a good one though.....
They are ran down the passengers side. And hey cool about the whole "see thru". Mine are about a see thru as you can get. No packing at all even new. But they are loud. That truck was my neighbors alarm clock where I used to live.
I can tell you for a fact that running a single 3inch exhaust does not compare to running dual 3inch exhaust....it was the single biggest bang for my buck compared to any other mods that I have done!
I don't doubt that. Were yours both run on the passenger side too? Got any picts?
Yes, both down the passinger side, the boys did a great job, sorry no pics.....you should of looked at it on Sat.
Well, if I had known I would have. Can you take and post some pictures for us? Does it go over the crossmember, between it and the tranny like the stock one too?
I believe mine go over the crossmember just like the stock one did. I'll tke a pic and get the computer smart wife to help me put it up if noone beats me to it.
