Sponsored by: Real Truck
Front end clunk?
Old Jan 22, 2007 | 08:59 AM
V10'nr's Avatar
V10'nr
Unhappy Front end clunk?
I have a clunking noise under the truck . This is a 2000 250SD 4X4 v10.
The noise is coming from the front while driving and sounds like it is right under my feet. Happens when I hit like road imperfections of wash board area's. Looking for area's to look. Any advice before I climb under the truck in the cold would help. Did this in the summer also, but was not as noticable.
Came here since I recieved help with my locking hubs and lubricating them.
Thanks again in advance.
Old Jan 22, 2007 | 09:07 AM
chuck641's Avatar
chuck641
reach behind your front tires and try shaking the u-joints where the axle shaft comes out of the axle and into the hubs. If it moves around it is time for new seals. this may be your clunking problem.
Old Jan 22, 2007 | 10:34 AM
V10'nr's Avatar
V10'nr
Will check there chuck. BUt it does not clunk when driving down a smooth road. That is if you can find one around michigan.
Old Jan 22, 2007 | 10:50 AM
Fredvon4's Avatar
Fredvon4
The early trucks had issues with lower ball joints and the wheel hubs are also a problem... they are a sealed unit...I know of a few that made a lot of racket on bad roads but sounded fine on level smooth roads
you might also have missing for worn out leaf spring isolator pads...the nylon/plastic seperators between leafs that can cause a lot of noise during compresion or rebound but usualy not a thump more a screach or scrape sound... But I have seen leaf speing isolator rubbers in the eye end get worn enough for the connector bolt/pin to hit the eye and sound like a clunk so check out the condition of the leaf springs at the shackles
Another common clunk is NOT from your front end but actually at your center bearing carrier for the two piece drive shaft ....the slip yolk needs to be removed and the splines greased... early units were not assembled with very much or any silicone grease and the splines start to bind and then release and sounds like a loud clunk
Old Jan 22, 2007 | 11:35 AM
FortyFords's Avatar
FortyFords
Don't forget swaybar end links ,if he has a swaybar in the front
Its common also
Rich
Old Jan 22, 2007 | 02:14 PM
V10'nr's Avatar
V10'nr
I will look at all. Thanks guys. That is why I joined this forum.
I was also thinking that it might be the spring shackles also.
Old Jan 22, 2007 | 06:52 PM
ExcursionSVOand5.0's Avatar
ExcursionSVOand5.0
Mine's doing the same thing...sway bar end links are failing and it's pretty common according to my dealer..will be replaced under warranty once I get a few other things wrong to make the $100 deductible worth it.
Old Jan 22, 2007 | 11:17 PM
Lost Hog's Avatar
Lost Hog
Mine does it too, but only when the AC is on.......I think its a shutter or clutch or something.I dont know
Old Jan 23, 2007 | 09:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sway bar end-links is what I'd look at first (and cheapest, probably).
Thread moved to Superduty forum - this isn't a V10 question
Old Jan 23, 2007 | 01:31 PM
kanertop's Avatar
kanertop
Its common also
Rich
This would be my guess.
