Pos to neg ground conversion problems
Old Jan 22, 2007 | 06:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
PS -- does your truck have a MagicAire type heater or the old Ford type? In either case, I fear the fan may run backwards if you go neg. ground. Wipers, too.
Old Jan 22, 2007 | 06:23 PM
areed1's Avatar
areed1
Before I fried the regulator, the heater and wipers worked correctly with negative ground. The ammeter is backwards, but I can't figure out how to switch it. It's the old style with the wire passed through an induction loop, not a hot and ground wire.
Old Jan 22, 2007 | 06:42 PM
mtflat's Avatar
mtflat
Ammeter is easy - disconnect the wire, pull it out of the loop on the ammeter, push it thru the loop the opposite direction and reconnect it.
oneye
Dec 16, 2014 06:29 PM
36th Tom
1947 and Older Ford Trucks
Mar 22, 2012 08:20 PM
Steves55
Jun 17, 2010 07:59 PM
Narwhal
Oct 17, 2005 01:40 PM
CCotten
Electrical Systems/Wiring
Oct 19, 2004 04:48 PM
