I have a 96 f-250 460 ,E40d The overdrive light flashes and the motor only runs on 1 bank of injectors, i have replaced the pcm no change. the transmission will only work in 2nt or sometimes reverse. I scanned for dtc,s and the snap on scanner would not communicate. any help would be greatly appreciated.
There's a one wire connection between the two banks for the 12 volts. This wire may have issue's. Its gonna be a splice in the harness where all the red wires come together. you can check for 12v with key on At each inj connector red wire. Leave the other wire alone..Use a test light on the red wire only.
Dick
