4.9 misfire
Old Jan 21, 2007 | 08:09 PM
Jason6969's Avatar
Jason6969
4.9 misfire
I have 94 e-150 4.9 auto, traveling at highway speed it has an occasional miss or stumble, it is noticeable at idle, idles smooth then just hesitates and goes back smooth. Has new plugs, distributor, wires,.
Thanks,
Old Jan 29, 2007 | 07:11 PM
cocot's Avatar
cocot
Did you change the coil? I upgraded the coil in my 4.9 and it made a noticeable difference in engine smoothness.
Old Jan 29, 2007 | 07:23 PM
pfogle's Avatar
pfogle
It sounds like the TPS or IAC may be going bad. Pull the codes and see what the computer is telling you. Then go from there. Also just because the CEL isn't on does not mean there aren't codes stored.
Old Jan 29, 2007 | 07:25 PM
Jason6969's Avatar
Jason6969
Thanks! I might try one , Did your 4.9 stumble and hesitate going down the road and also at idle. It does run better at idle and the miss stops when I pull the plug out of the MAP sensor, would this indicate a bad sensor?
Old Jan 29, 2007 | 09:31 PM
pfogle's Avatar
pfogle
Possibly, usually when the MAP sensor goes bad it won't run at all. Mine had a 351w in it, and yes it did the same thing. We put a new fuel pump in it, and a complete tune up including filters and it went away. If the TPS voltage is dropping it will cause was feels like a miss too.
