Head Gasket Time
Old Jan 21, 2007 | 04:22 PM
RangerPilot's Avatar
RangerPilot
Head Gasket Time
Well...I knew the coolant had been going slowly. I just hadn't known where. Wasn't in the oil...couldn't see any obvious leaks.
Was looking at the bolts on the passenger side exhaust manifold today...saw a little green trail running down. Sure enough...antifreeze is leaking a little bit. So small it's not noticeable (the coolant tank went down maybe an inch in a month) and wasn't a liquid trail, it was dry, looked like algea kinda.
The driver's side head seems easy to pull...the passenger side looks impossible though, the A/C condenser is right there.
Suggestions on how to go 'bout it? Thanks a lot. And an estimate on the time it will take me to do both would be wonderful.
Old Jan 21, 2007 | 04:27 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Zak, the A/C condensor is not located on the engine, it's located in front of the radiator. With a "real" service book in hand, such as one from Ford or Alldata, (book is used for reference for things like head bolt torque), the job will take a long afternoon (learning curve is required). Buy quality gaskets and not ones from oriental countries.
Old Jan 21, 2007 | 04:56 PM
RangerPilot
I got the Ford service manual on CD.
My mistake on the condensor. The large, insulated box next to the passenger side head is what I meant.
Fel-pro sound good?
Thanks for the reply.
Old Jan 21, 2007 | 05:04 PM
Bob Ayers's Avatar
Bob Ayers
I would check the lower intake bolt torque, and gaskets first. The 4.0L of your vintage is known for this problem. Since the exhaust manifold bolts are
above the head gasket, I find it hard to believe that the head gasket leaking would get on the exhaust manifold bolts.
Oh, and the "large insulated box" is your heater core / AC evaporator box!
Old Jan 21, 2007 | 05:09 PM
RangerPilot
No no sorry I was unclear in my first post. The leak is below the manifolds. I was looking at the manifold bolts when I saw the leak for the first time. I'll get a picture of it once the camera gets charged, it makes more sense visually.
I can't see the source of the leak...I can just see the trail it left.
Old Jan 21, 2007 | 07:17 PM
fordboy_52's Avatar
fordboy_52
that one might be fun to do in the truck but i know it can be done. if the head is connected via bolts than it shouldnt be a problem. now if they are connected via studs, than it might get complicated. you should be able to unbolt the head and pry it up (GENTLY) and slide it towards where the intake was or up the deck. make sure u reset your lash with a feeler guage when you put your heads back on
Matt
Old Jan 21, 2007 | 08:04 PM
Tiggie's Avatar
Tiggie
Head gaskets are never any fun on anything but a Briggs and Stratton.
Old Jan 21, 2007 | 10:47 PM
RangerPilot
Well...with the leaky rear main and the head gasket apparently only leaking fluid slowly out the side (being it's not in the oil)...I'm thinking I'll put it off until Spring Break, when the tranny was coming out to be rebuilt and have the clutch replaced, I'll yank the engine and just do it with the engine out. Heck, maybe just rebuild it for college.
As long as the coolant stays clear and the oil non-milky, it'd be ok to run it for another two months, right?
Old Jan 21, 2007 | 11:34 PM
arctic y block's Avatar
arctic y block
Ya i would if ya can afford the coolent. I might even pull the rocker cover and tighten the head and intake bolts down a little. But then if ya are going to pull it in two months than just run her.
Old Jan 22, 2007 | 05:18 AM
Bob Ayers's Avatar
Bob Ayers
Once again Zach, check the lower intake bolts/gasket!!!
Old Jan 22, 2007 | 06:02 PM
RangerPilot
I'm 'bout to go check the torque of and tighten the lower intake bolts.
here's a couple of pics. First from the side, then from the bottom. You'll notice on the side I rubbed a small blank spot about halfway up and it hasn't been covered since I did it for whatever reason.
The antifreeze appears liquidy but it's actually a solid mossy sort of stuff, as I said. Sorry the bottom picture is blurry.
Bottom:
http://i112.photobucket.com/albums/n...leakbottom.jpg
Passenger side, through the wheel-well, just aft of the shock mount:
http://i112.photobucket.com/albums/n...zeleakside.jpg
Old Jan 22, 2007 | 06:39 PM
Fordsflylow's Avatar
Fordsflylow
I agree, check the lower intake's torque and gasket. I have the same truck, motor as Zach except I have the auto tranny.
I recently noticed a very small coolant leak where the return line for the tranny bolts onto my radiator for its cooler. I never paid much attention to the fact that my Ranger has a plastic radiator until noticing that leak. Should be fun trying to tighten that without breaking the radiator!
Old Jan 22, 2007 | 06:41 PM
Fordsflylow
Sure appears to be coolant!
Old Jan 22, 2007 | 07:38 PM
RangerPilot
It is coolant...but it's dry...caked on. I've no idea how long it's been on there...not many things that require you to look through that gap, plus it's a normally dark area. It was by pure luck that I noticed it.
Old Jan 22, 2007 | 07:59 PM
CowboyBilly9Mile
Bob is right about retorquing the lower intake bolts in an effort to solve the leak; old/early 4.0's are vulnerable to leak issues concerning this gasket. You'll probably be surprised at just how loose these fasteners are (I always have been and the word fingertight comes to mind in a few instances). You may also be surprised to know that most engines are installed with the front slightly raised. I'd have to look at a diagram to confirm this but it's entirely possible that juice from a leaking lower intake is running to where you're finding it due to slope and windage while driving. Of course, it would be really nice for you to get in there with a flashlight and a small mirror mounted on a rod and look around the lower intake/head faying surface in an effort to positively pinpoint the leak source. And in the end, it's worth realizing that even if it is the lower intake gasket, retorquing may not solve the problem due to it leaking for awhile.
