Sponsored by: Real Truck
Turn a longbed into a shortbed?
Old Jan 21, 2007 | 02:41 PM
GA_FORD's Avatar
GA_FORD
Pretty simple question...is it possible to shorten the frame of a longbed 2003 F250 6.0 diesel and put a short bed off a crew cab or super cab? I've seen it done on 1/2 ton ford and chevys but not or a 250. Thanks
Old Jan 21, 2007 | 03:09 PM
PHWLEE's Avatar
PHWLEE
For a real simple answer, yes it is possible. They make stretch limo's, and they can shorten one too. You need to think about the frame, exhaust, driveline, and smaller stuff like parking brake cables and fuel tank. Since the axles area of the frame has the "hump" going upwards, the frame would probably have to be cut in the straight section, then re-attached by either welding it or heavy riveting or bolts. Not sure how sturdy that would turn out though. I probably missed a few things, but that's a general idea of what needs to be done. Might be easier and safer to just swap trucks.
Old Jan 21, 2007 | 03:49 PM
GA_FORD's Avatar
GA_FORD
Thanks for the response, you may have answered my 2nd question of who could do a mod like this? May find someone who does limos? Any ideas?
Old Jan 21, 2007 | 08:29 PM
mlytle's Avatar
mlytle
dare we ask why you would want to do this? seems like it would be cheaper and easier to just swap trucks...
just curious.
Old Jan 21, 2007 | 08:46 PM
stevenn1's Avatar
stevenn1
Convert longbed into shortbed? But why?
Hmmmm.....Why? You would be spending lots of money just to basically make it into less of a truck. The 'bang for the buck' is just not there. Hmmmm.......
Old Jan 21, 2007 | 09:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
How short do you want it?
http://www.globalgroundsupport.com/towTractor.asp
Old Jan 22, 2007 | 09:27 AM
BritishBartender's Avatar
BritishBartender
Hope this helps.
https://www.ford-trucks.com/forums/5...eam-truck.html
Cheers,
Neil
Old Jan 22, 2007 | 08:53 PM
GA_FORD's Avatar
GA_FORD
That is exactly what I was looking to do!!!! except not lower but lift it 4 ins.
Old Jan 22, 2007 | 10:30 PM
IHbase's Avatar
IHbase
ummmmm..... why? Just go buy a short-bed for crying out loud...
Old Jan 22, 2007 | 10:41 PM
88FordF-150's Avatar
88FordF-150
IHbase, thats the easy way out. If he builds his truck himself, it is his CUTOM built truck. Yes it may cost alot, but in the end what is more saticfieing, havin a stock shortbed ford hoped up, or a cutom built custom design, hoped up truck. Some would say its just beating a dead horse, but if i had the money for that kind of a build, i would do it. I mean i wouldnt shorten the bed, but if i had the money there would be many changes made, not just tuning but some stuff that you dont see everyday.
Old Jan 22, 2007 | 11:16 PM
RJB1's Avatar
RJB1
Can you buy a shortbed regular cab 3/4 or 1 ton? I don't think I have seen one in the states...
Old Jan 22, 2007 | 11:32 PM
jorlee's Avatar
jorlee
I'd look for a place that stretches semi's and puts dump bodies on them. Probably would be cheaper than a place that does limo's.
Old Jan 22, 2007 | 11:45 PM
Frankenbiker's Avatar
Frankenbiker
Nope; at least not easily, anyway. But you can get them in Mexico, and I've seen a couple with Mexican plates running around here in TX...
-blaine
Old Jan 23, 2007 | 03:00 PM
GA_FORD's Avatar
GA_FORD
Yup! The reason I don't jost go buy a short bed is............Because they don't make'em here!
Old Jan 23, 2007 | 03:21 PM
CARV's Avatar
CARV
Check this out for those who want a short bed 250 / 350. http://earnhartbuilt.com/
