2004 4.2L P2195 P2197 codes
Hey John.
Welcome to FTE!
Glad to have you join us and hope to be able to help.
Here's some info I dug up.....
(possible causes)
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
italics = my best guesses
Welcome to FTE!
(possible causes)
Induction System:
Vacuum Leaks
PCV system
EGR System:
Leaking gasket
Stuck EGR valve
Base Engine:
Oil overfill
Cam timing
HelenT
Modular V8 (4.6L, 5.4L)
10-09-2016 12:35 AM
