Floor pan differences?
Old Jan 21, 2007 | 11:58 AM
fairlaniac's Avatar
fairlaniac
I'm doing a ZF S5-47 swap into my F150 w/M5OD. Is the floor pan/hump different between the two?
Thanks!
Old Jan 21, 2007 | 06:18 PM
Tdvjensen's Avatar
Tdvjensen
No there is no difference. I did the swap in my 92 f150 along with 2wd-4wd conversion and the only thing that I needed to do was remove the cover for the t-case shifter.
Old Jan 21, 2007 | 06:23 PM
fairlaniac's Avatar
fairlaniac
Tdvjensen,
Thanks! One more thing. I've never had my transfer case off. Is there a gasket between the transfer case and transmission?
Thanks,
Old Jan 21, 2007 | 06:28 PM
lostin90s's Avatar
lostin90s
There was a gasket between trans /xfer on last zf I worded on Good luck
Old Jan 21, 2007 | 06:42 PM
fairlaniac's Avatar
fairlaniac
Thanks for the help!
Old Jan 21, 2007 | 08:05 PM
Tdvjensen's Avatar
Tdvjensen
Even if there is a gasket, there is no fluid between the two thanks to a rear seal in the tranny and the front seal on the transfer case. I just used rtv silicone to keep the dust out and help the treads seal on the bolts, as I know they go into the fluid chamber on the old 205 t-case, which I used in my conversion.
Old Jan 21, 2007 | 08:57 PM
fairlaniac's Avatar
fairlaniac
I figure it would be easy enough to use a gasket if required.
Jaa55
Jul 29, 2014 03:34 PM
Indybeer
Nov 8, 2011 03:39 PM
falcon1964
Jul 11, 2007 07:36 AM
dadstruck
Sep 6, 2006 12:20 AM
djshoser
Dec 30, 2004 06:42 AM
