General Diesel Discussion
Help wont start
Old Jan 21, 2007 | 11:42 AM
chris12's Avatar
chris12
Help wont start
Hey guys well im haveing trouble with my truck. I filled it up with diesal in Michigan today and drove it fine and then when i went to shut it off it was fine. So i got and start it put it in reverse and it shut off. JUst liek if i would turn the key off. So could there be water in the fuel and my fuel filter is done. Need some help ASAP. AS im stranded at a guys house right now.
Old Jan 21, 2007 | 02:34 PM
Flame Out's Avatar
Flame Out
Your message is a little vague.
Does the truck start and idle to operating temperature but kill when you engage reverse gear?
Does the engine crank but not ignite?
Which engine are you refering to?
Please don't spray ether into your air intake plenum unless the engine is cranking and, therefore, diluting the ether with air. Better not to use ether at all. IF you needto use a staring fuel, try WD-40 or lighter fluid.
