Horn won't stop
Old Jan 21, 2007 | 09:43 AM
drewtbrown3's Avatar
drewtbrown3
Horn won't stop
I have a 1999 F-250 Diesal and one fine day I hit the horn and it went on and it wouldn' shut up until I had to pull the circuit breaker from the left hand side under the steering wheel. Someone told me it is a bad relay in the steering wheel where you push to honk the horn. If it is where can I get one? If it's not what do I do. I'm a first time user.
Old Jan 21, 2007 | 07:16 PM
fl1a's Avatar
fl1a
I saw one listed at the autozone web site for around $5.00. You might want to get a
repair manual also. The Haynes manual has pretty decent wiring diagrams. Any good
auto parts shop should be able to come up with one based upon your vehicles' specifics.
Old Jan 21, 2007 | 07:19 PM
fl1a's Avatar
fl1a
That was for a horn relay, not the switch at the steering wheel.
Old Jan 22, 2007 | 01:02 PM
jimdandy's Avatar
jimdandy
You can quickly check the relay by subbing one of the other relays in it's place. If it continues to honk with the sub relay, it is not a relay problem.
The horn honks by grounding the relay thru the horn ring/button to the colum. This is a wire, not a relay as there is no relay in the steering column, and if this wire shorts, it will continue honking. You will probably have to pull the steering wheel to find it. jd
Old Apr 10, 2007 | 09:54 AM
SWAcapt's Avatar
SWAcapt
Horn won't stop
I too have a horn that wont stop. Can't find a relay for the horn. It's an '05 F350 PS. Any help would be appreciated.
Old Apr 10, 2007 | 12:06 PM
Franklin2's Avatar
Franklin2
99% of the time I have found the problem is in the steering wheel. But the diagram I have shows the horn relay on a 2005 located in the fuse box. I believe in 2005, the fuse box is now located on the passenger side kick panel.
Old Apr 10, 2007 | 09:58 PM
BruteClaw's Avatar
BruteClaw
2005 Fuse Pannel
From personal experience, the 2005 F150 fuse pannel is behind the pasenger side kick pannel.
Old Apr 15, 2007 | 02:45 PM
SWAcapt's Avatar
SWAcapt
I took my truck (f350) to the dealer to fix the horn under warranty and when I went to pick it up, the keyless entry no longer works, the dome light stays on, and the instrument cluster message cycles through all four door ajar messages. I just laughed and said "nice try, call me when it'd really fixed".
stbernard
Jan 13, 2017 04:13 PM
Frank33884
15
Mar 23, 2016 10:29 AM
bkohne1
Jul 29, 2015 01:30 PM
F350moneypit
19
Feb 4, 2013 01:46 AM
lee
Oct 30, 2000 12:57 AM
