Offroad & 4x4
Weird feeling at accelaration
Old Jan 21, 2007 | 08:53 AM
triton54's Avatar
triton54
mornin yall, i have a 97 f-250 (7 lug jewel) 5.4 V8, 4" rancho lift and 35" buckshots, its a 4x4 with the 10.25 rear end. every time i come to a stop then go to take off again rather i baby it or hammer it it feels like something in the rear isnt fully engaged. kinda feels like the gears or something drop into a slot then i get traction. theres no high rev or nothing its just instant when i hit the gas. no noises or anything neither just a weird feeling like something may be loose. I aint sure of what gears i have in this thing because i bought it as she sits. i do know that there arent many gear options for this type of rear at least thats what im told so also what are the most common gears to run with this set up. im pretty new to the off road world and yall may be happy to know i left my ex wife because she wouldnt let me have a big truck lol...along with a few other reasons, well now i have my 4x4 so lets see if we can make my experiance better.
Old Jan 21, 2007 | 08:55 AM
triton54's Avatar
triton54
by the way maybe its a 3" lift, how can i tell that also, and whoever said 3" or 4" depending on what i got will accept 35's b.s. i still have tire rub when turning all the way, where can i get spacers for a 7 lug?
Old Jan 21, 2007 | 03:03 PM
75F350's Avatar
75F350
If your truck is equiped with a LS unit, it could very well be the unit slipping, or chattering. Once in a while a unit will feel kinda funny like you have mentioned. The solution is to simply add some friction modifier to condition the clutches. I am hoping that there are no loud noises, or abnormal sounds associated with you problem.
Second item regarding your rubbing problem. The solution will probably not get solved by adding spacers. If your truck is rubbing the fenders now, the problem will get worse by making the wheel stick out further. I suspect the rubbing problem is in the front, not the rear, and only when you turn really sharp?
Old Jan 21, 2007 | 03:19 PM
ramboss429's Avatar
ramboss429
You may just need to do some minor trimming on the bottom of your front fender to fix the rubbing.
The acceleration problem sounds like you have a LS rear end that isn't engaging properly. I had the same thing happening in my '03 SuperCrew this fall.
Old Jan 21, 2007 | 06:53 PM
JeremyH's Avatar
JeremyH
Yeah, sounds like the LS. Start by draining the diff and inspect everything. Clean and refill with gear lube and LS friction additive.
Old Jan 22, 2007 | 05:52 AM
triton54's Avatar
triton54
the fenders are fine it rubs inside
Old Jan 22, 2007 | 08:47 AM
ramboss429's Avatar
ramboss429
Are you running the stock wheels?
Old Jan 22, 2007 | 05:37 PM
triton54's Avatar
triton54
yeah they have 7 lugs.....aftermarkets are damn near unheard of
Old Jan 22, 2007 | 08:53 PM
MuddyAxles's Avatar
MuddyAxles
7 Lugs?
I've seen 4,5,6,8, and 10 lug wheels. Never saw a 7. What kinda axle is it?
Old Jan 22, 2007 | 11:00 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
does it have rear lift blocks for the lift kit? are they stacked with the factory blocks? if so i would check for movement there and/or loose ubolts first
Old Jan 26, 2007 | 11:47 PM
triton54's Avatar
triton54
im pretty sure its the 10.25 but yep 7 lugs, and yeah theres blocks under the rear leafs
ydoc23
Jun 21, 2017 10:22 PM
catman900
Nov 2, 2013 08:18 PM
sandman1984
Jul 27, 2011 12:12 AM
m350
Nov 28, 2007 11:04 AM
triton54
1997 - 2003 F150
May 30, 2007 05:30 PM
