370 4 barrel intake?
Old Jan 21, 2007 | 07:54 AM
Nedcampion's Avatar
Nedcampion
I'm new to this motor, i want to change to a 4 barrel carb. What intake will fit? This is a 79 f600 with only 12000 miles on it. I'm looking for more low end power. Can any one recomend what 4barrel carb would work for this motor?
Thanks
Old Jan 21, 2007 | 08:18 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking 4bbl Intake
Any 460 / 429 intake will work . The 370 that was in our sevice truck
was a 4BBL we tried 600 to 750 cfm carbs on it , worked the best with
a 650 Edelbrock , hollys had a tendency to ice up on a cold / damp morning.
worked allrite otherwise not as good on gas as the EDL.
Have A Good Day ------- Hotwrench
Old Jan 21, 2007 | 03:47 PM
Nedcampion's Avatar
Nedcampion
Thanks Hotwrench! Can you recomend a intakefor low end tourque?
Old Jan 21, 2007 | 05:16 PM
monsterbaby's Avatar
monsterbaby
stock cast iron intake would be a good low rpm intake and the cheapest option, you can probalby piick one up pretty cheap otherwise, an edelbrock performer.
Old Jan 22, 2007 | 07:23 AM
HOTWRENCH's Avatar
HOTWRENCH
Intakes
What Monsterbaby said is right on, the cast intake with a 1in 4 hole spacer
and your good to go!
Have A Good Day-------Hotwrench
