best oil for the 6.0
Old Jan 21, 2007 | 08:16 AM
vatreefarmer's Avatar
vatreefarmer
Is there an oil that can be run year round here in Va. The spec sheet does not recommend 15-40 below 30* (winter lows here often into teens) and summer highs sometimes around 100 which eliminates 10-30, I would guess that if so it would be a syn. But which one? Is there a reasonably priced one?
Old Jan 21, 2007 | 08:30 AM
slowmans's Avatar
slowmans
ya u can run rotell 5-40 syn year round, i pay about 15.00 a gallon at wallyworld, ive got aout 8 oil filters in the closet, so oil changes will be a little cheaper for the next 40k miles !
Old Jan 21, 2007 | 08:45 AM
vatreefarmer
Thanks! My local Ford dealer told me AFTER I changed oil w/ Rotella dino that there was a TSB warning against the use of Rotella due to foaming, which would cause erratic running. Is that not a problem with the Rotella syn?
Old Jan 21, 2007 | 08:47 AM
slowmans's Avatar
slowmans
i havent noticed any erattic running? good luck guy!
Old Jan 21, 2007 | 09:24 AM
mrxlh's Avatar
mrxlh
Originally Posted by exiled
Is the oil consumtion and idle problems fixed if you get the oil level down if it was the oil level that created the problem?
Yes, lowering the oil level cured both of these problems. The foaming of the oil (caused by being overfull) is what was causing the drivability issues. Not the actual oil involved. If you filled with the recommended 15 qts, and say 1-2 qts was left in the hpop, you were now 1-2 qts overfull.
Old Jan 21, 2007 | 09:31 AM
vatreefarmer
Thank you both!! It feels good to have my newbie questions answered so quickly. Since Ford doesn't list a 5w-40 oil on their lubricant page in owners manual, will there be any warranty issues?
Old Jan 21, 2007 | 09:37 AM
mrxlh's Avatar
mrxlh
No, no warranty issues from running the 5W40 as long as it is CI-4+ rated, which Rotella T syn is.
Old Jan 21, 2007 | 09:38 AM
Keith1984's Avatar
Keith1984
The diesel supplement lists 15w40 preffered from 30 up and acceptable down to 10 and recommended for towning. 10w30 preffered from 30 down to -10 and accedptable up to 90. 5w30 or 5w40 acceptable from 30 on down and 0w30 from 0 down.
Old Jan 21, 2007 | 10:01 AM
vatreefarmer
Yes, as Keith points out, the Ford diesel supplement only allows for 5w-40 below 30*, not for use at higher temps?
Old Jan 21, 2007 | 10:10 AM
Keith1984's Avatar
Keith1984
I don't see that they could have a warranty issue with using 5w40 year round. When I took mine in to ford for oil change I asked for 5w40 as the temps have been dropping below 0. They told me they never heard of 5w40 and only use 15w40 all year in the diesel. Right now it's 4 degrees with a high of 14 which is well below the listed minimum temp for 15w40.
Old Jan 21, 2007 | 10:52 AM
05powerchoke's Avatar
05powerchoke
Originally Posted by paul horvath
ok what would be the best oil for the 6.0
i just had mine changed at the stealer 85 bucks and i asked the service rep about rotella T 15-40 and said some of the guys are having probems with the rotellaT something to due with certain chemecal compounds within the oil are just not up to par for the 6.0
so i guess the ford stealers just want you to use motocraft syn.
what say you!
i just did a oil change with rotella T15-40 and materials cost me $80.23 so i think u made out well...
Old Jan 21, 2007 | 10:55 AM
PSD DickW's Avatar
PSD DickW
Posting Legend
A local diesel performance shop in my area, with a very good reputation, said to use 15-40 year round until about 10,000 miles and then consider changing to synthetic.
Old Jan 21, 2007 | 11:00 AM
  #28
GoblesKen's Avatar
GoblesKen
Smile
My dealer charges $59 for oil change and tire rotation; some sort of mark-down for trucks bought there. It has always seemed like a GREAT deal to me. Too bad your dealers do not want you back near the showroom more often.
Old Jan 21, 2007 | 01:10 PM
  #29
chumley's Avatar
chumley
This begs another PSD newbie question: In my Ducati motorcycles I wait until the engine has about 6K miles before I switch to syn oil. Is there a recommended mileage before you switch syn oil in a PSD? My 2007 6.0 has 2200 miles on it right now.
Chumley
Old Jan 21, 2007 | 02:42 PM
  #30
Keith1984's Avatar
Keith1984
I was up to walmart earlier and looked to see what they had for motorcraft oil. They had the 1-quart bottles of motorcraft 15w40 diesel oil and on the back it says for temps below 20 use 10w30.
