Aerostar Ford Aerostar
NAPA code reader ?
Old Jan 20, 2007 | 11:04 AM
ckutter's Avatar
ckutter
NAPA code reader ?
Will the $30 code reader from NAPA have the ability to reset the codes ? From the picture on the web site. It doesn't look like much.
Old Jan 20, 2007 | 01:04 PM
xlt4wd90's Avatar
xlt4wd90
I think you can reset the codes on most EEC-4 (OBD-1) computers by pulling the battery cable and turning on the headlights. I'm not so sure about the later OBD-2 computers.
Old Jan 20, 2007 | 05:00 PM
96_4wdr's Avatar
96_4wdr
coder reader/scanner code clear function is handy in that it does not clear the NAM ECU/PCM computer memory learned engine/tranny unique performance parameters based upon driving style, hill/flat terrain, fuel quality, etc
from Ford Service CD manual
How to Clear the Continuous Memory
NOTE:
Do not disconnect battery to clear Continuous Memory. This will erase the Keep Alive Memory (KAM) information which may cause a driveability concern.
1. Run the Key On Engine Off Self-Test.
2. When the DTC's begin to be displayed, deactivate Self-Test:
-- STAR Tester: Unlatching the center button (up position).
B-- All others: Remove the jumper wire from between Self-Test Input (STI) connector and the Signal Return Pin of the DLC.
-- Scan Tool: Pushing the STOP button.
3. Continuous Memory will be erased in the PCM.
B for all of us DIYers
pull the neg. - batt. leads clears not only the stored fault codes but also the NAM memory, returning the ECU/PCM to factory default programming which may cause start and run problems until relearned= abt 20 miles of varied driving...
Old Jan 21, 2007 | 06:56 AM
Pablo-UA's Avatar
Pablo-UA
ckutter!
If you have OBD-II aero, you need code reader for SAE Standard. There are K-L line OBD-II readers, but they dont work on aero.... Well, now I see often universal readers based on ELM 327 chip, they read all the standards (ISO K-line, ISO L-line, SAE (ford and GM) and CAN), but Aero needs no special program, universal programs, like ScanPro do it well.
If you have OBD-I aero, you need no tool.
Old Jan 21, 2007 | 10:19 AM
ckutter's Avatar
ckutter
There is a black box with a white connector hanging under the dash, right below the steering wheel.
I don't see much behind the battery. What am I looking for behind the battery ? I assume I was looking for some sort of tail to hook to. Everything is all strapped down.
Old Jan 21, 2007 | 10:24 AM
ckutter's Avatar
ckutter
I was mistaken its a 5/95 build. Almost at the end. May that is a OBD 2 port that I see.
Old Jan 21, 2007 | 11:42 AM
96_4wdr's Avatar
96_4wdr
Cool Deleted
Old Jan 21, 2007 | 11:46 AM
96_4wdr's Avatar
96_4wdr
OBDI EECIV click
OBDII EECV click
Old Jan 21, 2007 | 01:41 PM
ckutter's Avatar
ckutter
Well I found the #1 connectors up under the washer jet. So I'm out to read blinks.
Old Jan 21, 2007 | 03:10 PM
ckutter's Avatar
ckutter
Here's what I found. First 539. Turn off the A/C dork.
Then I get 212. What does that mean ?
With no codes for my tranny issue. Which one of the connectors on the drivers side of the tranny is the shift solenoid ?
Old Jan 21, 2007 | 04:30 PM
Aeroman59's Avatar
Aeroman59
212= Loss of IDM input to EEC or spout circuit grounded.
Old Jan 21, 2007 | 09:14 PM
ckutter's Avatar
ckutter
Now the question is, where do I start ?
Old Jan 21, 2007 | 09:31 PM
ckutter's Avatar
ckutter
Take a look at this thread. Exactly the same issue. With exactly the same code.
https://www.ford-trucks.com/forums/3...?highlight=idm
command37
Feb 22, 2016 08:35 PM
captinphill
1978 - 1996 Big Bronco
Dec 15, 2015 02:26 PM
hismuddpuppy
15
Jun 7, 2009 12:16 PM
KCMAGERS
May 8, 2007 12:36 AM
Quantrex
Sep 2, 2002 06:53 PM
