Bronco II Ford Bronco II
body lift
Old Jan 19, 2007 | 10:03 PM
youngfordguy's Avatar
youngfordguy
body lift
i was thinking of puting a 3 inch body lift on my b2 dose one have to change any of the steering components
Old Jan 20, 2007 | 02:26 AM
Help I M Stuck's Avatar
Help I M Stuck
the kits come with a short shaft that lengthens it..it's a simple install. I've done two bronco's in my past.
Old Jan 20, 2007 | 03:27 AM
HappyJack's Avatar
HappyJack
I had a small amount of feed back (binding) in the rag joint on my 84 with the 3" body lift. Not much at all with a 2". I installed a PA 2" then a 3" body lift. I have been told that this is less of a problem with the later model BII steering column that has a u-joint in place of the rag joint.
Old Jan 20, 2007 | 10:09 AM
kernel-panic's Avatar
kernel-panic
I know the kits they offer on truckperformance.com (Performance Accessories & Superlift) usually come with the steering and shifter extensions, etc. Also, depends on local laws (i.e., a 3" body lift here in VA is illegal, if I remember right). I don't think I'd go over a 1-2" (or less) body lift, personally. You want to keep your CG as low as possible, especially one the BIIs, as they are fairly topheavy as it is. Raising it too much would make it more suceptible to rolling, IMO. You may also want to look into the Bushwacker Cut-Out Flares.
Old Jan 20, 2007 | 12:03 PM
youngfordguy
thanks i want to get the 31's i have in my back yard to fit with out cutting the body or spending a lot of money.
Old Jan 20, 2007 | 02:19 PM
Help I M Stuck
you could always go for a budge boost..coil spacers in the front and add a leafs in the rear.
Old Jan 20, 2007 | 09:01 PM
youngfordguy
ya i might just go for a four inch lift to. eventualy i am going to put a 5.0L in it when i get some cash to do it with.
Old Jan 20, 2007 | 09:28 PM
Help I M Stuck
Lift it up..they look good when done..I've got 4inch suspension, 3 inch body, 35x12.50x15 BFG MT/s on mine and wheel it regularly..
Old Jan 21, 2007 | 02:04 PM
youngfordguy
also has any found info on a solid front axle conversion
Old Jan 21, 2007 | 02:28 PM
frankenbroncoII's Avatar
frankenbroncoII
.therangerstation.com/tech_library/Dana44Swap.html here try this.
Old Jan 24, 2007 | 03:36 PM
rebocardo's Avatar
rebocardo
I put a 2" lift on one of my BIIs so I could run the exhaust straight back out between the body and bumper (better for deep water and deep snow). Personally, I am not a big fan of body lifts, especially on the BII because I think it tends to tear the floor seams on the driver and pass. side when you have it crossed up.
Old Feb 18, 2007 | 11:17 PM
rwmorrisonjr's Avatar
rwmorrisonjr
I just installed a 3" on my BII tonight and did get some binding on the steering shaft. I dropped the mounting plate about 1/2", loosened the mount bolts on the dash and adjusted the column until there was no more binding. Then I tightened it all back up and it works great.
Go ahead and lift it. As long as you don't drive it like a sports car you won't have an issue with rolling. Slightly wider tires will help too.
Old Feb 26, 2007 | 09:39 PM
brianlr77's Avatar
brianlr77
I personally would never use another body lift again. I had used em on two BII's and wheeled em regularly, nothing crazy just trails. Both floors were destroyed by the twisting of the body on the frame, The floors literally tore and cracked from the crazy leverage the 3 inch lifts create. At first i didn't notice then heard and felt poping underneath my feet on the drivers floorboard... thought my bushings had problems or something.
Could not find out what was going on, so I decided to pull the carpet back and make sure the bolts were tight. Thats when I saw that the body had completely torn and cracked at the seams around the bolt anchor area.. BOTH sides of BOTH BII's and yes the bolts were tight and in fact the body sheet metal was still bolted to it, just no longer part of the truck! The trucks were pristen and zero rust... all socal trucks. Not to mention it looks stupid seeing a truck with a giant gap under the body and the bumpers not sitting right.
If your sure you want to do one, as there a very cost effective method to stuff some tires , try 1 or mabey 2 inches..
But I guess to each his or her own
