Factory Propane: Engine Code 9.
Old Jan 19, 2007 | 09:23 PM
pjlandry's Avatar
pjlandry
Hi Folks.
I'm hoping someone here can tell me.. 1990 E-150/Econoline with 4.9l Propane only. The VIN shows an engine code of 9. VERY HARD to find data about it. Neither Haynes or Chilton even mention this flavour. All Data confirms that this is the 4.9l/300 Propane. Since the VIN reflects this I can only presume it's factory. Which makes sense.
However, I found a CANP solenoid connected to the wiring harness. The solenoid obviously looks used, and neither air input or output were connected. It was just "sitting" between the intake manifold and valve cover. Since I've removed, drivability seems a bit better.
According to my research, the whole concept of CANP is to "recycle" gasoline vapours when the engine is off. But this is a propane setup! The are no gasoline vapours!
Can anyone give a good reason as to why this unit could be connected?
Thoughts?
Thanks all.
-Pauli
Old Feb 1, 2007 | 12:51 AM
scottfreeman's Avatar
scottfreeman
How do you like the propane setup? I have been intriqued by this fuel for years. I think a turboed 300 I6 on propane would be pretty cool.
PaulsEdge
Alternative Fuels, Hybrids & Mileage
Jan 9, 2017 07:09 AM
dutchlincoln79
Feb 24, 2009 04:03 AM
pjlandry
Feb 2, 2007 09:56 AM
know_fear
Jan 7, 2006 06:14 PM
Old5
Computer Chips & Tuners
Nov 18, 2002 07:15 PM
