04 Expy Power Window Problems
Old Jan 19, 2007 | 06:04 PM
allanhilliard's Avatar
allanhilliard
Thursday, just below freezing outside, I get in the truck, start it, let it warm up etc. I drive down the street and lower both front winidows as the scraped off ice is still there. They went down fine but wouldn't come back up. After a while, and a couple of freezing miles they slowly started to respond. I have noticed that since then they travel up and down very slowly, up more so then down. Has anyone else had this problem? The dealer is going to look at it, but it would be nice to know if they found the problem or if they just lubed something to pacify me. The rear windows travel at a nice speed, so I know that either they are faster than they should be, or that the fronts are slower.
Thanks
Old Jan 19, 2007 | 10:50 PM
BordnBill's Avatar
BordnBill
My passenger side did that about a month or so ago. I took it in, and the window motor and regulator were shot.
Old Jan 20, 2007 | 07:30 AM
hookd's Avatar
hookd
you could try some silicon spray on the window tracks this is a common fix for slow windows
Old Jan 20, 2007 | 10:40 AM
04markIII's Avatar
04markIII
i had the same problem on my 03. went down, but not up right away. replaced the drivers multi-switch...problem fixed.
Old Jan 20, 2007 | 01:34 PM
allanhilliard
Do either of these involve removing the door panel?
Old Jan 21, 2007 | 05:17 AM
hookd's Avatar
hookd
The switch panel just pops off seperate from the door panel but to get at the tracks you should take the door panel off
