stutter step
Old Jan 19, 2007 | 04:51 PM
14psd's Avatar
14psd
stutter step
Hey guys. I have a question about the my truck. First of all have any of ya'll had this prob...when I accelerate lightly or just cruizing and have to give her a little go pedal she bucks/stutters a bit. If I give her a bit more go pedal it stops. If I just romp on it and lay her to the floor I have plenty of power. The stuttering only appears under light pressure on the go pedal. I took a buddy of mine to a diesel performance shop to pick up is truck and asked the mechanic what's up with mine. He seems to think its the pedal throttle position sensor. Which for those that do or don't know what this is, it's on the top part of the go pedal and has an oval plug on it. I can't find one at any of the parts houses and the stealership wants $770.50 for it. OUCH!! Ford only sells this part as the pedal assembly with both sensors on it, the other one is the idle sensor. Does anyone know where to get one any cheaper? Or what else my options are.
Old Jan 19, 2007 | 05:00 PM
ForemanES's Avatar
ForemanES
First off can you pull up any codes with your superchips programmer?
Old Jan 19, 2007 | 05:08 PM
14psd's Avatar
14psd
no codes come up...darn it I meant to put that in there. I have used the superchip to read the codes and a snap-on one and no luck.
Old Jan 19, 2007 | 05:14 PM
ForemanES's Avatar
ForemanES
Well I only found this one but its for a 460. (click here)
I bet you can keep checking on ebay to find one.
I dont have any experience with this problem sorry I cant help you out a little more.
Old Jan 19, 2007 | 05:17 PM
14psd's Avatar
14psd
Thanks forman it has to be for our psd s. the plug is oval on ours. I'll keep looking I guess. I don't know what to do. $770.50 is toooooo much right now for a STUPID sensor. GGGRRRRRRRRR
Old Jan 19, 2007 | 05:22 PM
ForemanES's Avatar
ForemanES
WAIT A MINUTE!!!!!!
(click here)
it has an oval plug!! you might be in business
Old Jan 19, 2007 | 05:38 PM
14psd's Avatar
14psd
Thanks again foreman. The entire plug is oval. The outside of the plug is oval too
Old Jan 20, 2007 | 11:30 AM
RLC2269's Avatar
RLC2269
I HAVE THE SAME PROBLEM WITH MY TRUCK. does it kind of stutter alittle when it shift too? I have been told that my torque converter is failing. sense i have no clue as to what to do right now, i will let you put a new throttle sensor in yours and see if that fixes the problem. lol.let me know if that solves your problem. Thanks Rob.
Old Jan 20, 2007 | 02:44 PM
tjbeggs's Avatar
tjbeggs
http://www.trademotion.com/partlocat...?siteid=214072
thats one of the best places to get the pedal assembly.
carguy3j
92
Jun 9, 2021 06:16 AM
ScaldedDog
27
Feb 19, 2016 11:05 PM
doc54321
2004 - 2008 F150
18
Sep 23, 2015 12:33 AM
Carpenter Mark
May 27, 2015 05:49 AM
1994_F150_302M
83
Jan 19, 2006 10:43 AM
