question on fluid change tech article
Old Jan 19, 2007 | 04:49 PM
c-dub's Avatar
c-dub
Question question on fluid change tech article
i plan on installing a external tranny filter and change my tranny fluid in my 96 bronco. i read this article...
https://www.ford-trucks.com/article/idx/9/057/article/Changing_ATF_Fluid_in_a_E4OD_and_4R100_transmissio n.html
and would like to know what would keep the old fluid from contaminating the new fluid? would you need to plug the tranny? any ideas... or thoughts?
thanks
c-dub
Old Jan 19, 2007 | 09:14 PM
Casey's Avatar
Casey
There is a little mixing, but not enough to worry about. You don't need to plug the tranny.
Old Jan 20, 2007 | 01:09 AM
aurgathor's Avatar
aurgathor
Unless the old fluid is *really* bad, you don't need to worry about a few quarts of ATF that may stay in there.
FreeDevin
Jun 3, 2024 11:36 AM
Buck268
Mar 9, 2013 08:26 AM
Mazookie
18
Nov 18, 2012 01:34 PM
DBGrif91
Mar 21, 2011 12:12 PM
emidino
Mar 7, 2011 10:34 AM
