CCRM problem ?
Old Jan 19, 2007 | 03:36 PM
Wishbone's Avatar
Wishbone
CCRM problem ?
My wifes windstar has a problem when temps get below zero the fuel pump will not start thus van has no fuel pressure and won't start. When things warm up it works fine. It always happens on a restart, away from home. Sometimes you would think there is still heat in the engine but no start. Heard something about bad seal and moisture, but wonder if this could be because this has been occassionally been happening for about 3 years now. Thank for any Help
Old Jan 21, 2007 | 09:21 PM
LxMan1's Avatar
LxMan1
Sounds like possibly a bad fuel pump relay or EEC relay perhaps. Is there voltage going to the pump when this occurs?
Old Jan 22, 2007 | 10:14 AM
Wishbone's Avatar
Wishbone
There is voltage, but only the signal from the computor, no amperage. Testing is a problem because after only a few minites in a warm shop it works. This doesn't happen only a very few times in extreme temp
Old Jan 23, 2007 | 12:01 AM
LxMan1's Avatar
LxMan1
I wonder if you have a bad fusable link that may be separating in really cold weather.
V8SHO
19
Apr 24, 2017 05:36 PM
Dallas James Jungers
Oct 4, 2016 12:47 AM
neale.smith3191
Feb 21, 2016 10:19 PM
battont
16
Sep 9, 2013 06:53 PM
jl2695
18
Sep 24, 2006 09:52 AM
