rearend info
Old Jan 19, 2007 | 02:12 PM
DOPE3's Avatar
DOPE3
Smile rearend info
how do i find out what rearend my 1994 f150 flareside has need to change out carrier bearing. its a 5.0 [302] supercab thanks
Old Jan 19, 2007 | 02:16 PM
Dustin1690's Avatar
Dustin1690
Check out your axle code on the door jamb if its 19 its a 3.55 non limited slip if its h9 that would make it a limited slip so if it has the letter and # LS just number is non 17 i think is 3.08 there is also a vin decoder in articles which matches the axle code to the rearend
Old Jan 19, 2007 | 02:18 PM
alz's Avatar
alz
Are you asking gear ratio or which rear axle do you have?
Rear axle is Ford 8.8
Gear ratio shoul be on a tag attached to the rear diff. Also should be on the door jam tag under axle code. When you get the code go to "Articles/Specs" at the top of this page and decode your info.
Old Jan 19, 2007 | 02:32 PM
DOPE3's Avatar
DOPE3
Thanks Guys Great Info
Old Jan 19, 2007 | 02:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Rear axle codes found on VIN plates have to be decoded in the rear axle section (4000) of the Ford parts books. Ratios are not listed in a VIN decoder book.
Old Jan 19, 2007 | 02:40 PM
alz's Avatar
alz
This is the page you need.
https://www.ford-trucks.com/article/...r_Decoder.html
Old Jan 19, 2007 | 02:48 PM
DOPE3's Avatar
DOPE3
Thanks Guys I Got It Know Thanks Again
