something broke
Old Jan 16, 2007 | 10:18 AM
mr.inbetween's Avatar
mr.inbetween
something broke
just wondering if anyone could tell me what possibly broke in my steering column on my 93 4-4 automatic,when i pulled it in drive yesterday,i thought i heard a snap,now my shifting lever is quite floppy and i cant get it in park, i only have drive, neutral and reverse..... thanks for any help...
Old Jan 16, 2007 | 12:12 PM
95Ford4x4's Avatar
95Ford4x4
could be something on the shift rail that runs down the top of the column. i think that thing's made of cast aluminum and breaks real easy, only couple bolts holding column up under dash, i'd drop the column down and take a look, or, pull the cover on the steering column, two pieces top and bottom between steering wheel and dash, and you might be able to see far enough down the top side of the column to see the problem, then drop the whole column to fix it.
Old Jan 16, 2007 | 01:12 PM
mr.inbetween
thanks 95,i'll check it out and let you know how i make out.
Old Jan 19, 2007 | 12:56 PM
rookiemistake's Avatar
rookiemistake
hey there.
Had the same thing happen on my '95. I replaced the shift cable and everything was dandy from their. Ford has always made a crappy shift cable.
Old Jan 19, 2007 | 03:27 PM
mr.inbetween
thanks i'm tearing it apart tomorrow to look for the problem,....jackie
