changing rear end
Old Jan 18, 2007 | 11:52 PM
56f100pickup's Avatar
56f100pickup
changing rear end
I was wondering if anybody knew what kind of rear end would fit on a 56 f100
Old Jan 18, 2007 | 11:59 PM
Brian_B's Avatar
Brian_B
Go read this article. It should answer any question you have.
https://www.ford-trucks.com/article/...ial_Swaps.html
Old Jan 19, 2007 | 01:29 PM
daveheld's Avatar
daveheld
I noticed a number of rear options, but no mention of installing an Independent Rear Suspension... has anyone considered this as a viable option?
dave
http://www.truckIRS.com
Old Jan 20, 2007 | 01:37 PM
keisha9's Avatar
keisha9
just about any f100 9" from the late 50 all the way up bud.
Old Feb 3, 2007 | 04:20 PM
51ford's Avatar
51ford
On my 51-f-1 I bolted in a 71 f-100 9 in. rear. I went to the yard with atape center tocenter was the same drum to drum the same&lug bolt pattern the same. had to do a mod with shock mounts tho.good luck mike.
Old Feb 3, 2007 | 05:37 PM
hotrod351's Avatar
hotrod351
i thought about a independent rearend out of an older t-bird. i was told if i found one with a turbo 4 cylinder or 8 cylinder it comes with a 3:25 posi. suppose to be easier than the volarie front end install.
Old Feb 3, 2007 | 06:12 PM
daveheld's Avatar
daveheld
yes, the rear Tbird or Lincoln Mark 8 IRS install is quite easy... I'm working on a bolt-in one as well to make it even easier.
I would be happy to answer any questions you may have - email or call. More info may be found at truckIRS.com
dave
Cocoa Beach FL
Old Feb 4, 2007 | 02:45 PM
Soldierboy's Avatar
Soldierboy
daveheld
does this install interfere with a fuel tank that is mounted behind the rear axle between the frame rails?
Old Feb 4, 2007 | 03:24 PM
daveheld's Avatar
daveheld
I'll take some photos from directly overhead this week to point out the areas of interference... You could help me by letting me know the year and model of the truck you are asking about... as well as any specific dimensional information you can provide of the gas tank relative to the frame rails and axle centerline.
dave
Cocoa Beach FL
truckIRS.com
Old Feb 4, 2007 | 11:50 PM
PDW HOTRODS's Avatar
PDW HOTRODS
A dodge 8 3/4 out of an erly 60's half ton will also work, and has
the same bolt pattern also.
Old Feb 5, 2007 | 07:40 AM
CharlieLed's Avatar
CharlieLed
Flat-Out Engineering in Anaheim, CA sells a bolt-in kit that will enable you to install a Corvette IRS in your F100. I fabricated my own frame mods on my 50 Merc to install a 92 C4 IRS, the kit is worth the money!
Old Feb 7, 2007 | 08:58 AM
daveheld's Avatar
daveheld
Soldierboy
I tried to send you an email with photos of the Tbird IRS positioned between some frame rails to give you an idea of the size... but I was unable to send you an email.
If you would like to see these photos - email me : dave@truckIRS.com
dave
Cocoa Beach FL
