2000, f240, 4x4 disengages
Hi,
I have a 2000, f250 4x4, with the selector switch on the dash. Recently, the truck disengages on it's own. Also, it will try and re-engage and I will hear a grinding noise and then it will bang into 4x4 when it engages. Does any one have any ideas what the problem is? Thanks Tony
2000, F250 4x4 Disengages
Yes, If I Lock The Hubs Manually It Stays In 4x4. The Electric Motor Does Engage But It Pops Out Of 4x4 And After A While, It Will Try And Engage That's When The Grinding And Banging Into 4x4 Occurs. Where Would I Find The Vaccume Line. I've Greased The Front End And Never Noticed A Vaccum Line. Thanks Tony
The vacuum line is at the top of the axle housing, right by the rotor. It is a very small rubber line and could be off or broken. The transfer case will only engage when the hubs lock, thats why it stays in 4X4 when you manually lock the hubs. If you look over top of the tire you will see the line.
I did check the rubber lines to the front hubs they were fine, we then got a vacuum guage and tested the front seals that keep the truck engaged and we had one side maintain the pressure for 20 minutes and the other side dropped within one minute so the front seal is bad. I appreciate all of your assistance.
Tony
Tony
I have the same Issue
Good day, I did a quick search on the forum and low and behold you had to same problem I do on my wife's '03 F-350. I also checked the vacuum lines from the hubs and they look alright. Where is the front seal located that you said was bad on one side? Appreciate the help.
