1978 - 1996 Big Bronco
rpm surges
Old Jan 18, 2007 | 08:19 PM
msd0912's Avatar
msd0912
rpm surges
My 1993 5.8 bronco gets this random rpm drop when i stop at a stop light or come to a stop after driving for a little while. It never has completely stalled out. It happens a lot more when i have the headlights on and when i have anything electrical turned on like the heat. The voltage meter also drops randomly. Then when i get going again everything goes back to normal. Also sometimes when i come to a stop it doesnt happen. Any ideas would be great....thanks
Old Jan 19, 2007 | 10:13 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, www.fordfuelinjection.com will show you how. you might have a bad alt as well.
try a search on this issue its been discussed a bunch.
Old Jan 20, 2007 | 10:48 AM
Erik940's Avatar
Erik940
My 87 302 did that also. turned out the fuel pressure regulator was bad. does your exhaust smell rich?
Erik
Old Jan 22, 2007 | 01:50 PM
msd0912's Avatar
msd0912
yes it does smell rich...how hard is it to put in a new fuel pressure regulator?
Old Jan 23, 2007 | 08:16 AM
Kemicalburns
have you pulled codes yet? why throw money at an issue that is unknown yet? the codes will give you a better ballpark idea of were to start.
Old Jan 23, 2007 | 10:30 AM
Erik940's Avatar
Erik940
I don't have a scanner to read the codes so I paid somebody to diagnose then repair. I also remember that while it was running high rpms for warm up it ran fine but as soon as it went down to normal rpms it started surgeing. I don't know off hand what the psi should be but, the shrader valve for testing the fuel pressure is easy to get to. Mine is located next to the distributer on the fuel rail going to the injectors.
Erik
