96 B3000 Engine racing.
Old Jan 18, 2007 | 08:00 PM
highgearonly's Avatar
highgearonly
Hello all,
I just parked my 93 F150 for some much needed repair work & picked up a 96 B3000 this week. It is a 5 speed manual 4x4 & is great little truck! Has the usual issues for a truck with 135,000 miles.
Odd thing happening right now is engine continues to race with foot off gas when I am driving. It idles at around 1000 rpm. When I shift gears at say 2500 with foot off gas, engine speeds up to 300 and stays there. Same thing if I depress clutch & take my foot off gas while driving.
Any ideas? Maybe IAC?
Thanks
Joe
Old Jan 19, 2007 | 07:15 AM
Rockledge's Avatar
Rockledge
IAC would be a good bet. Also, have someone sit in the truck and press the gas pedal while you watch the throttle cable, make sure it's not getting hung up or anything.
Old Jan 23, 2007 | 08:48 AM
highgearonly
I got a chance to check it this past weekend & it all works freely but one of the throttle return torsion springs was broken. I bent a new leg on & re installed, it may have made a slight difference but problem did'nt go away.
In searching the forum, I had noticed a lot of posts about the same problem so I am checking the IAC and TPS along with looking for vac. leaks next.
Thanks
Joe
