Sponsored by: Real Truck
Front End Clunk
Old Jan 18, 2007 | 07:21 PM
toozak's Avatar
toozak
Front End Clunk
I know that this question has probably been posted before but I couldn't find anything on a search. I have an '05 Super Duty Crew Cab 4x4 with manual hubs and floor 4x4 selector and the issue that I have is if I have the hubs in the locked position and the truck in two wheel drive I still get a clunking noise when I make a sharp turn. I guess the question I have is is this normal all of the trucks I've had prior to this one had the ESOF and thus the auto hubs.
Thanks for the help.
Old Jan 18, 2007 | 07:40 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, you will get a bit of binding, clunking and steering feedback when your front hubs are locked and you are making a sharp turn (steering wheel against the lock). That is normal.
If you get a loud grinding type noise, then you need to look at your front end.
Old Jan 18, 2007 | 08:21 PM
toozak's Avatar
toozak
Thanks for the quick reply and for the info.
Old Jan 19, 2007 | 06:42 AM
hookd's Avatar
hookd
do you leave the hubs locked alot without being in 4 wheel drive?
Old Jan 19, 2007 | 08:44 AM
redford's Avatar
redford
I lock my hubs if I think there may be a need for 4 wheel drive, or if I am going off road for any length of time. That way, if I need 4x4 all I have to do is engage the transfer case.
You only need to be stuck once, with muddy water covering your hubs, to learn this lesson.
Old Jan 19, 2007 | 10:21 AM
hookd's Avatar
hookd
I was just making sure he didn't leave them locked all the time it sucks to wear stuff out before you need to.
Old Jan 19, 2007 | 03:30 PM
toozak's Avatar
toozak
Hookd - I do not normaly leave the hubs locked, the other day we were supposed to get some bad weather so I locked them when I pulled out of my driveway and when I pulled into a parking on my trip I noticed the "clunking" noise when I turned into the lot and into a parking space.
Old Jan 19, 2007 | 08:17 PM
hookd's Avatar
hookd
I was just checking man I've seen it before. Redford hit it on the head though when turning you hear all sorts of noises and can normally feel it binding in the corners just try and make wider turns when locked in
Old Jan 20, 2007 | 08:06 AM
96f150's Avatar
96f150
Sounds normal to me, thats just the bind in the steering knuckles. Just try not to make any sharp turns, as your not doing your outbound u-joints any justice.
Old Jan 20, 2007 | 03:24 PM
toozak's Avatar
toozak
Thanks again all for the info. I just wanted to make sure that it wasn't something that I should get it to the dealer to look at.
Old Jan 20, 2007 | 06:35 PM
fyrflyr18's Avatar
fyrflyr18
redford: what is the loud grinding noise? I just experienced it yesterday. I was thinking maybe a broken hub, or a hub that wasn't fully engaged. Ball joints were replaced 6 months ago. Thanks, sorry for hijacking.
Old Jan 20, 2007 | 07:59 PM
clipper1's Avatar
clipper1
The grinding noise is the outter u joint, or the hub. But most likey the outter u joint. Look at it see if you can move side to side at all, or if there is any rust on the end caps.
Old Jan 20, 2007 | 09:31 PM
bobbynj66's Avatar
bobbynj66
So you understand why they are clunking even though the transfer case is in 2wd the hubs being locked the front wheels are driving that axle and using more fuel also.
Ironoutlaw2010
2004 - 2008 F150
Jul 28, 2015 08:32 PM
MTGunner
23
Dec 27, 2014 06:20 PM
holman794
Mar 5, 2012 05:47 PM
Beanpod
1997 - 2003 F150
Apr 1, 2007 10:43 PM
Rando75
Aug 20, 2003 03:55 PM
