painting brass
Old Jan 18, 2007 | 12:52 PM
Green Streak's Avatar
Green Streak
painting brass
I have a 223 in a 63 which I have been cleaning up over the winter. I removed, cleaned and /or painted almost everything under the hood. I steel wooled the radiator reservoir and it came up gleaming brass. I know the originals were painted black but I like the look of the brass. Can any one tell me the reason these were painted and will leaving it as is cause any problems?
Thanks in advaance, Greg
Old Jan 18, 2007 | 01:19 PM
CN Spots's Avatar
CN Spots
Probably just painted it to cover up flaws and to match the rest of the engine compartment. The brass will tarnish/dull rather quickly and require regular polishing (also a good reason to paint it). POR 15's Glisten PC is a clearcoat that is formulated for polished surfaces like brass and aluminum... I don't know how well it will hold up on a hot radiator but a clearcoat would be the route I'd take if I wanted to keep it shiny. Leaving it unpainted will not hurt the radiator's performance, asside from a little corrosion which, again, clearcoat should prevent.
spots
ProStreetDriver
Jun 1, 2016 09:53 PM
MPH Racing
17
Apr 21, 2015 08:35 PM
RickBraden
All Things Towing
May 19, 2012 06:27 PM
tinman52
Paint & Bodywork
Dec 20, 2009 08:37 PM
NJ239Y
Sep 10, 2005 02:22 PM
