rear sway bar
Old Jan 18, 2007 | 10:47 AM
hungry_aggie's Avatar
hungry_aggie
Question rear sway bar
what kind of sway bar works best and where can i get one. 2003 4x4 6.0psd
Old Jan 18, 2007 | 10:59 AM
DS3's Avatar
DS3
I think mine is a Helwig. I got it from a custom trailer/ fab shop. You can get them from most 4x4 shops- ie. 4Wheel Parts, etc. Just get a BIG one!!
Old Jan 18, 2007 | 11:07 AM
200Proof's Avatar
200Proof
For about half the price of the Helwig you can get the Ford 30mm sway bar for a F250 and it does the same thing.
Old Jan 18, 2007 | 12:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
REALLY!? Last time I priced out everything you need for the Ford bar to work it was like double what the Hellwig costs from JC Whitney. The bar and hardware is only like $120 from JC...if memory serves. 'Course I bought mine almost 5 years ago so....
Old Jan 18, 2007 | 07:13 PM
jdadamsjr's Avatar
jdadamsjr
Ha Ken - that time flies by doesn't it
I too got mine from JC for my 03 - guess I don't drive as fast anymore cuz I haven't felt the need to get one for the 05 Ex...
or maybe it already came with one ???? have to crawl underneath as soon as this ice leaves DFW...
Old Jan 18, 2007 | 07:30 PM
EpicCowlick's Avatar
EpicCowlick
Sorry to be such a newb about this, but why a rear sway bar? What indicates a need for one?
Old Jan 18, 2007 | 07:37 PM
Big Sky's Avatar
Big Sky
Jones-The sway bar makes this large vehicle handle a lot better. I put a Helwig on mine and it drives way better down the highway's curves. Got mine from JC Whitney. Keep an eye out for special coupons with their catalogs...
Old Jan 18, 2007 | 07:41 PM
EpicCowlick
When you say it handles better, I don't think you're referring to slaloms through cones... I just picked up a 2000 limited v10 and really like the ride. Seems to be just the right mix of stiffness and softness. My only complaint is that it wanders in the lane when on the freeway. You kind of have to pay attention or the vehicle will easily drift out of your lane. Would a rear sway bar help keep the truck from wandering?
Old Jan 18, 2007 | 07:45 PM
Big Sky's Avatar
Big Sky
I forgot to mention that most of the early Excursions did not come with the rear bar. It makes a huge difference and if it weren't for this forum, I would not have installed it.
Old Jan 18, 2007 | 08:24 PM
Stewart_H's Avatar
Stewart_H
This is the most common problem Excursion owners face, and after learning about the fix on this board, address, and then rectify.
Excursions suck when it comes to holding a lane. And it's only magnified when you tow something. Tow something with a lot of weight and the problem is exacerbated even more.
Type in "wander" in the search function (choosing only the Excursion forum for the search) and you'll get tons of reading.
Most of us change the front and rear springs to OEM springs found on the F250. Some do just the rears with Landyot radius rods. Some do the rear springs and sway bar.
Others, like me, change the fronts and the rears, add a sway bar, upgrade the shocks and never again worry about steering wander...even when towing close to 8K pounds of trailer and moving horses.
Getting back to the question at hand, when I priced the Ford bar (and related hardware) and compared it to the Hellwig I eventually purchased at JC Whitney, it was approximately the same price.
Stewart
Old Jan 18, 2007 | 08:50 PM
EpicCowlick
This is surprising news. For a vehicle built for towing, it sounds like an engineering oversight. Don't get me wrong, I'm a huge fan of Ford products after driving a GM truck, suv and two minivans over 15 years. The Fords have been so much better in quality and effortless to maintain. I have an Expedition which has been a great vehicle even for towing my heavy (10K) travel trailer. It tracks down the road straight as an arrow trailer or not. It just doesn't have the power to pull so that's why I picked up an Excursion. Thanks for the advice on the suspension upgrades, I'll get those taken care of.
Old Jan 18, 2007 | 11:33 PM
cprdummy's Avatar
cprdummy
Regarding lane wander...will installing dual front stabilizers help remedy this? I have been thinking of trying that first. Also, is the rear anti-sway bar a tough thing to install? Thanks, Bill
Old Jan 19, 2007 | 12:54 AM
Stewart_H's Avatar
Stewart_H
From what I've read, no.
One, because the steering stabilizer only affects bump steer. The wander is not caused by uneven pavement, potholes, etc.
Two, because some have put forth a hypotheses the wander is caused by normal deflection of the inadequate front and rear springs, created when the tires travel over the roadway surface, allowing the back end of the Excursion to push-steer the front of the Excursion ever so slightly. This hypothesis also explains why lateral body movement from turning maneuvers, lane changes, strong winds, or towing will induce the wander.
In my limited, lay opinion, this makes sense because it seems some tires can minimize the impact the "rear-end push" applies to the front of the Excursion.
When I had Michelins on the Ex, the wander was not as noticeable as when I replaced them with Toyo Open Country's.
Because of this, I surmised (whether rightly or wrongly) the construction of a tire can dampen the wander effect.
Stewart
Old Jan 19, 2007 | 03:37 AM
Rushmore X's Avatar
Rushmore X
Got mine from JC Whitney. Made a big difference in towing the boat, especially going down steep grades in the mountains.
Old Jan 19, 2007 | 08:01 AM
twisted289's Avatar
twisted289
Stewart
I have to agree with this statement, I went from the Firestone Trans Force 2's to Dunlop RVxt's and the wander was decreased. I did add the Firestone Ride Rite airbags and they definately help the sway. I havent towed with my Ex yet, but my camper is 9200lbs so I guess i will see how it does in the spring
