Copper Fuel Line
Old Jan 18, 2007 | 10:03 AM
scottie2hottie's Avatar
scottie2hottie
Copper Fuel Line
I was told copper was no good for use with fuel, we have used it for years in the derby cars with no issues. Can anyone put forth some knowledge on this?
Old Jan 18, 2007 | 01:39 PM
kotzy's Avatar
kotzy
Copper cracks from vibration, and having fuel pump across an engine could be a real bad problem. I have seen cars burned up and I knew a heck of a lady who
burned to death from a gasoline fire. Copper is bad, as is rubber line unless it is changed from time to time. I might add even steel can crack. Copper is the weakest link in the chain I'd avoid it. By the way the steel exhaust headers we use on engines today get hot enough to light off a spray of 50/50 coolant. I didn't think that was something that could happen but I saw it and put the fire out. I also saw a power steering fluid fire, line cracked and sprayed on a cat.
Kotzy
jacob_powerhouse
Sep 22, 2016 08:58 PM
ddeflyer
Feb 19, 2015 12:39 PM
MLBaranowski
Feb 14, 2015 09:25 AM
1955effie
Mar 29, 2006 01:50 PM
dsc
Feb 7, 2003 08:24 AM
