tornado fuel saver
Old Jan 18, 2007 | 09:21 PM
  #31
wendell borror's Avatar
wendell borror
I don't use k&n filters anymore myself, I have a k&N intake, but an AEM filter, they just pass to much dirt for my likeing. For sure buddy, we don't want to get the k&n thing going again ha ha.
Old Jan 18, 2007 | 09:48 PM
  #32
tomtoc's Avatar
tomtoc
i've started quite the discussion over just a true or hoax question
Old Jan 18, 2007 | 10:00 PM
  #33
wendell borror
Yeah, isn't it funny how the dumbest stuff can turn into 6 pages, I guess thats how board we are. Lets addmit it, we have no lives ha ha.
Old Jan 19, 2007 | 10:40 PM
  #34
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
tomtoc, how many people have you had to tell to plug in the SECOND power connector into the motherboard
And FYI.. i'm both ASE.. AND Microsoft certified ... all the more reason to keep working on cars! woohoo
Microsoft certification is about as good as earning your Jiffy Lube U. diploma
Old Jan 19, 2007 | 10:55 PM
  #35
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Yeah, I have had to replace my muffler bearings twice so far... And just like those Cat to dog converters you can't buy used ones, have to be new.
Bah, and that is what I get for responding to a post on page one, and not reading page two or three first.
Old Jan 21, 2007 | 11:15 PM
  #36
tps93ranger's Avatar
tps93ranger
The Tornado and the flo blade are junk. I have a buddy with a shop and a dyno and the Turdnado actually reduced air intake flo on a 302 motor.
Old Jan 22, 2007 | 10:24 AM
  #37
rubydist's Avatar
rubydist
Originally Posted by Dave257
Ok, we all have had some fun with the tornado, so maybe we can come to some good suggestions about how to increase fuel mileage. I keep hearing people in the forum talk about headers and intakes increasing fuel mileage...
Dave
I have real dyno data on my truck that says the headers actually hurt torque and horsepower under 3000 rpm. Not coincidentally, I am now getting slightly lower mileage than I was before the headers. The airbox mod is so slight that there is no significant performance or mileage impact.
The reason the tuners can get more power and more mileage is not because they put in more fuel or more air, but rather because they change the timing. If you are running in closed loop (14.7:1 af), the sensors are going to demand that the af ratio stays correct. The only thing you can do at that point (without mechanical changes to the engine) is to change the timing. If you advance the timing as far as you can without detonation, you will almost always have the most torque output from the engine (increased engine efficiency) and this is how the tuner gets more performance. The risk is you put too much timing and have detonation and destroy the engine. The factory tunes are a little conservative for a bunch of reasons, so the tuners can add some timing without having you destroy the engine (if you aren't stupid.) The timing maps on a ecu controlled engine are much more complex than the old mechanical advance distributors, so there is opportunity to make it a little better with the tune, but also more opportunity to screw it up, which is why tuning should be done by someone who knows and understands what he/she is doing.
Old Jan 22, 2007 | 10:26 AM
  #38
white cat's Avatar
white cat
Some people still believe that leaving your tailgate down will increase your gas mileage. When the exact opposite is true.
Old Jan 22, 2007 | 10:39 AM
  #39
Bart99GT's Avatar
Bart99GT
Just putting in more air will NOT help mpg.
Dave
You're assuming that cars run at 100% VE. In reality, most engines are between 75-85% VE at best. So being able to increase the VE will indeed give you better mileage.
Devices such as the "Tornado" don't work because any effect because as soon as the air gets to the throttle plate, it will straighten the air. Not to mention the ram air effect of the intake runners on a fuel injected engine causes the air to revert direction briefly. Any air rotation is quickly nullified in the intake system.
Old Jan 22, 2007 | 10:45 AM
  #40
wendell borror
But Ruby, remember the guy over at rps that was whinning because he dynoed his 4.0 ohv and only got an addition 25 hp after doing headers, intake, bama, e-fan and I'm not for sure if that was all, or whatever. So I would say it depends on the engine and not as a general rule. Awhile back 4-wheel offroad mag, put an k&N intake on a jeep grand cherokee with a v8 and dynoed and got 20 hp increase, so k&n used that for thier poster child for awhile. The 5.0 mustang guy's swore by a set of headers and an offroad pipe for 20. It depends on the engine and how restrictive exhaust manifolds, or airboxes are from the factory. The ranger happens to have a decent airbox and the ranger 4.0 sohc according to super six motorsports, has a decent exhaust manny's, except one side, I forget which one, but one side was a little restrictive , but not bad. The later ranger lima 4 bangers had a factory header more or less, on my 01, it looked like a header. The duratec focus has a very restrictive airbox and exhaust manifold, thier tuned for 0 emissions. An intake and header on a duratec focus can really bump the numbers. It depends on the engine.
Old Jan 22, 2007 | 12:37 PM
  #41
Dave257's Avatar
Dave257
Bart99GT
“You're assuming that cars run at 100% VE. In reality, most engines are between 75-85% VE at best. So being able to increase the VE will indeed give you better mileage.”
I don’t understand, say the engine is running at 50% VE. (Or whatever) And the intake improves it to 55%. That would mean that your putting more air into the engine on each revolution. So your have to add more fuel to keep the air/fuel mixture at optimum (about 14 to 1) for best combustion efficiently.
Now at 60 mph your turning the same number of revolutions per mile as before, but your putting more air and fuel through the engine. So you producing more HP but your also using more fuel. At any given speed your using more fuel. So where are the fuel savings?
Dave
Old Jan 22, 2007 | 12:44 PM
  #42
jimdandy's Avatar
jimdandy
The secret to exhaust/intake mods is tuning. The system has to be "tuned" for the results you want.
Horsepower comes with rpm: HP=torqueXrpm/5252, so when quoting horsepower gains you will generally be talking about a higher rpm operating band.
You put big headers on with larger exhaust, lower end suffers, top end gains. This has to do with gas velocity, not backpressure. Most try to interchange the two terms. Many do the same with horsepower/torque. They say horsepower when actually they are describing torque loss/gain.
You can't just put on a set of headers, do a dyno run, and say headers don't work because you didn't get the results you expected. It's a matter of balance.
jd
Old Jan 23, 2007 | 08:17 AM
  #43
KyThunder's Avatar
KyThunder
I don't know if this relates much to the subject but I know a couple guys that created some sort of resistance circuit that bypasses their O2 sensors (or simulates their sensors). Its hard to explain considering I don't know exactly how they did it but figured you guys might know what I am talking about. Basically they got a switch and it makes the engine operate as if it was just turned on and still below operating temp.
Is this hard on the motor? Because it is a noticable difference in the way the engine revs and noticable difference in power. I looked for this subject and found nothing.
Old Jan 23, 2007 | 09:54 AM
  #44
monsterbaby's Avatar
monsterbaby
Ok I don't have a life.
Old Jan 23, 2007 | 12:39 PM
  #45
Nighteyez's Avatar
Nighteyez
I think there is a law around here somewhere that states you cannot mention "460" and "good gas mileage" in the same sentence
And yes I have no life either
