please help! possible major problem.
Old Jan 18, 2007 | 01:55 AM
sus1799's Avatar
sus1799
Exclamation please help! possible major problem.
My 97 Expy XLT 4x4 is having some issue that I have never experienced. Upon take off, a thumping sound comes from the rear and possibly the tranny of the truck. It feels like the tranny is pulling hard. Most of the noise and the pulling feeling seem to come from the rear. I thought it was the rear diff but it also makes the pulling and thumping noise in AWD mode and in reverse. Another thing I noticed is when I make a full circle turn either way, the noise and thumping is more frequent.
I have new tires (bought about 4 months ago). I took off every tire and nothing seems to be broken or loose. In mid December, I took it in to the dealer to take care of a O2 sensor problem and the 4x4 not engaging. The 4x4 was resolved by a new module. The O2 needed a pipe fitting because the heater/AC condensation was leaking on it and it kept causing the "check engine" light to come on. They also did a tune up, oil change and filter, and all fluids topped off. The tranny is full of fluid. By the way, my truck has over 206k miles. Rear diff fluid was changed about 100k miles ago.
Someone please help if you can. Thanks.
Old Jan 18, 2007 | 03:09 AM
taisa899's Avatar
taisa899
u joints maybe
Jim
Old Jan 18, 2007 | 07:01 AM
hookd's Avatar
hookd
does it happen all the time or mainly when you are turning? I was thinking clutch packs but could be u joints to
Old Jan 18, 2007 | 11:42 AM
2000Expy's Avatar
2000Expy
Are you certain it has a LSD?
Old Jan 18, 2007 | 12:50 PM
sus1799's Avatar
sus1799
i'm not sure it has an LSD. it happens when going straight but more often when turning. u joints sound like a possibility but it wouldn't make sense if the sound is more frequent when turning.
Old Jan 18, 2007 | 01:05 PM
i1dery's Avatar
i1dery
Maybe you have one or two flat spots on the bearings in one or both of your
CV joints. I've had this same type of sound with another vehicle, replaced the
joints and all was well. Something to look into, good luck.
Old Jan 18, 2007 | 07:54 PM
FTE Herman's Avatar
FTE Herman
I wonder if this is the same sound I have been hearing for a long time (when under moderate load) and if it is I'd love to know the cause/solution.
Old Jan 24, 2007 | 06:57 PM
sus1799's Avatar
sus1799
hey everyone, i took my expy into the dealer and they said that the rear diff was now completely out. they opened it up and everything was broken. pieces of metal all over the place. $2700 to rebuild it! plus anything else that they might find! i'm not sure what to do. it has 208k+ miles and has been great to me and the family.
Old Jan 24, 2007 | 07:03 PM
EpicCowlick's Avatar
EpicCowlick
Seems like you can get an entirely new axle for that price. I haven't checked but you might check into ARB or Currie or even a local 4X4 shop that does these things.
Old Jan 24, 2007 | 07:21 PM
sus1799's Avatar
sus1799
i'm going to look into these and some local shops to see what i can get. anyone in or around san jose, ca that can point me to a local shop, would be helpful. thanks everyone!
Old Jan 25, 2007 | 12:58 AM
slenser's Avatar
slenser
The Gear Shop in Hayward I think. A bit of a drive but he does great work. Hopefully I'm giving you the correct info, I haven't been in CA for 12 yrs.
Old Jan 25, 2007 | 03:57 AM
skier-24's Avatar
skier-24
I would try a recycler (junkyard) and just swap the whole rear.
Old Jan 25, 2007 | 08:48 AM
fred_79f250's Avatar
fred_79f250
Take the junk out of the rear end, put it in 4-hi and you've got a front-wheel-drive Expy??
Old Jan 25, 2007 | 01:15 PM
slenser's Avatar
slenser
The front ends of our trucks are a locking differential. Eventually, it would break. Then you have nothing...
Now if we had a limited slip front diff, that would be doable!
I think the salvage yard is going to be your cheapest option.
Old Jan 25, 2007 | 03:26 PM
audichopper's Avatar
audichopper
I have a question about your 4x4 issue you had, i have a 98 Navigator that is not engaging into 4 wheel drive. After researching the forums it looks like a solinod or vacuum leak could be the cause. Was that it in your case? How much did the dealer charge you for the repair if you don't mind me asking and if you don't mind explaining the problem in a little more detail i would really appreciate it. Thank you for your help.
And would would recomend a junk yard replacement as well, some will actually guarentee it for a period of time too.
