Offroad & 4x4
leveling kit on a ttb
Old Jan 17, 2007 | 11:02 AM
bigsexy63's Avatar
bigsexy63
Hey yall,
I am kickin the idea around of adding a 2 inch leveling kit to my 89 f-150. the truck already has a 6 inch superlift and i'd really like to level the front out with the back. i'm curious to know if the 6 in axle drops are long enough to keep the suspention geometry intact. i have also thought about swapping in 8 in lift coils from skyjacker. right now i run 36x14.50 pj's and i want to go up to a 38 but i strongly don't like the idea of a body lift. any thoughts or ideas are much appreciated.
-Jeremy
Old Jan 17, 2007 | 11:05 AM
fishmanndotcom's Avatar
fishmanndotcom
yea lower the rear a touch. put a 1" shorter block back there or remove the bottom most leaf
free!
-cutts-
Old Jan 17, 2007 | 03:06 PM
billybob_81067's Avatar
billybob_81067
I'd also stick with the 36" tires unless you want to be constantly snapping axles.
Old Jan 18, 2007 | 10:08 AM
Pkupman82's Avatar
Pkupman82
Kudos on that one billybob! Any bigger you might concider SAS with moly axle shafts. My buddy is running 35 spline Mosers with 38x14.5 Boggers on his Dana 44, it has held up great... and he runs his stuff hard!
Old Jan 18, 2007 | 03:10 PM
kjg26's Avatar
kjg26
what leveling kit are you looking at? i'm interested in this as well. my trucks stock with 32 MTs. looking to level her out.
Old Jan 19, 2007 | 01:34 PM
i1dery's Avatar
i1dery
Dont know if it will work the same,
But when i put a 4" lift on my f-250 i just put an add a leaf in the back spring pack
and it leveled my truck out just perfact.
Old Jan 19, 2007 | 04:48 PM
kjg26's Avatar
kjg26
you talking about adding an "add-a-leaf" to the front spring packs? F150s run coils so that'd be a no go. As of now my trucks is higher in the back and lower in the front. So i either wanna put a coil spacer up front or new coils. I'm sure the truck would benefit from new coils. It is 17-18 Years old now.
Old Jan 20, 2007 | 01:58 PM
bigsexy63's Avatar
bigsexy63
yea the coils in the truck now are 2 year old superlift 6 in. lift coils. i was looking at just a simple coil spring spacer from bronco graveyard but i'm still concerned about the front end geometry being off, depending on whether or not the 6 inch drop brackets are long enough for 8 inches of lift.
Old Jan 20, 2007 | 02:03 PM
bigsexy63's Avatar
bigsexy63
also everyone if i do choose to just lower the back of the truck the rear blocks are stacked, i know a bad idea but i didn't have anything to do with that. can i remove the factory block with the spring tab and leave just the lift block, or will that throw off my pinion angle?
Old Jan 22, 2007 | 07:44 AM
i1dery's Avatar
i1dery
What i was saying is remove the blocks from the back and install just a add a leaf
to bring the rear down to match the front.
brangus82
Feb 15, 2016 11:25 AM
HuskyFlareside
21
Feb 11, 2016 11:29 AM
NBT22555
Jul 3, 2014 08:38 PM
b6fischer
May 10, 2014 10:31 AM
