9" rear end
Old Jun 4, 1999 | 10:20 PM
1kevin's Avatar
1kevin
9" rear end
I have a '55 F-100 with a stock 3.92 rear end and want to put in a 9". What I need to know is if the width is the same and any other info that may help me out. I already have 3" u-bolts. What other parts will i need?? Will I still be able to use my wheels? ( 5 on 5 1/2 ) Any info would be helpful.
Old Jun 13, 1999 | 10:31 PM
Glenn in TN
Guest
Posts: n/a
9" rear end
I have pulled the 9" out of my 57 (1st year). I can measure it up for you if you want, but I'm sure it will fit. I don't think much changed on the frame and body widths. It is 5 on 5 1/2", as I believe most F100's were until 1985. If you want mine, lets talk if you can get to the Memphis area. I think it has a 3.70:1 ratio.
Glenn in TN
Old Jun 19, 1999 | 04:13 AM
John Kovach
Guest
Posts: n/a
9" rear end
I installed a 9" rear from a 1966 Ford f100 pickup ,other than having to change the spring perch location it was a perfect fit,the rear from the 66 is only a 1/2" different from the stock rear. Looks good in my 1956 ford f100. If you use rear from the 67-up F100 you will find that the axle is alot wider than the 60's rear. "Good Luck and Keep on truckin"
Old Jul 29, 1999 | 08:01 PM
sdraymond's Avatar
sdraymond
9" rear end
Old Jul 30, 1999 | 05:34 PM
Paul Gayda's Avatar
Paul Gayda
9" rear end
Any truck 9 in rear fm 57 to 72 will bolt in.
Old Aug 21, 2005 | 05:59 PM
krfordnut's Avatar
krfordnut
I am in the process of installing the running gear out of a 1970 LTD including the 9 inch rear end in my 54 F100. Unfortunately, the housing is too long. What is the correct width of the housing? What wheel backset do I need to use? I would like to use extra wide fenders if possible for extra tire width and traction. Also looking for the best and economical rear suspension to run for the best weight transfer and best ride. I'm really leaning toward a 4 link with coil over shocks instead of leaf springs. Any info would help.
Old Aug 21, 2005 | 07:29 PM
ferguson777's Avatar
ferguson777
This might help you with one or two of your questions -
https://www.ford-trucks.com/article/...ial_Swaps.html
Old Aug 22, 2005 | 06:39 AM
g84t8f1's Avatar
g84t8f1
I'm Putting A 9" Out Of A 72 Ford 4x4 .will Bolt Right In .all 9" From 57 To 72 Out Of A Pickup Will Bolt Right In.you Do Have To Mome Your Shock Mounts.started Getting Ready To To Mine In This Weekend.put In All New Wheel Cyl., Seals, Ect.got The Old One Ready To Come Out.hope To Have It Done Next Weekend.will Post Pics.
Art
Rons50ford.
Mar 5, 2011 02:12 PM
tang87
Nov 2, 2010 12:13 AM
epp123
Apr 4, 2004 06:30 PM
88grandmarquis
Jun 24, 2003 03:37 AM
Omar8
Oil & Lubrication
Jan 11, 2002 12:52 PM
