torx bit
Old Jan 16, 2007 | 09:12 AM
WhiteTrashRanger's Avatar
WhiteTrashRanger
torx bit
does anyone know off hand what torx bit screwdriver to use to take the door panel off the inside of a 95 rangeR? i dont want to buy ones i dont need
Old Jan 16, 2007 | 09:55 AM
johnwaynejeep's Avatar
johnwaynejeep
Parts houses should sell torx bits one at a time. Take the truck to a parts house and start fitting until you find the right one.
Old Jan 16, 2007 | 10:20 AM
fordboy_52's Avatar
fordboy_52
or you can do like i have done and take a dremel and cut them with a slot (ill admin i stole this idea from ranger pilot) and i have used on numerous places on my ranger
Matt
Old Jan 16, 2007 | 12:40 PM
john112deere's Avatar
john112deere
IIRC correctly, the only Torx you need for the door panel is for the window crank, the rest are Phillips.
I think it's a T20, but I can't remember for sure. I picked up a set of 6 or 7 cheap screwdriver-style Torx drivers for $7 at the local cheap-tool outlet- look around before you buy a single, since it might not be worth it.
Old Jan 18, 2007 | 07:34 PM
WhiteTrashRanger
the last time i had to take it apart i was at wyotech and had my entire tool cage
