Im building a 1968 ford F-100 street truck. I am putting a 302 out of a 84 ford van. i am switching from points ignition to electronic ignition. the motor has the electronic ignition and the truck itself has the points wires. i have all of the wires connected except a white wire on the ignition box were does that white wire go.
Hello- Welcome to FTE! Your post has been moved to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
The white wire goes to the starter solenoid/relay. What the white wire does is retard the timing during starting so the engine turns over easier, especially on a hot day. So the white wire needs a 12 volt signal during cranking only. Hook it to the wire that triggers the solenoid to kick in that comes from the neutral safety switch.
You should also have another wire going from your solenoid to the ignition coil + terminal. Your old solenoid should have this extra small terminal called "I". What this does is bypass the ignition resistor in the harness to give the ignition coil a full 12 volts during cranking for a hotter spark. This makes it start much quicker, especially during cold weather. Make sure you are still using the original coil hookup that was for the points, since the old points system used a resistor or resistance wire for the coil. If you have run a new wire to the coil with no resistor, go buy one and install it. If you don't have the resistor, the ignition box and the coil will run hot.
