spedo cruise
Old Jan 15, 2007 | 06:42 AM
trailertower's Avatar
trailertower
Cool spedo cruise
2002 f 250 7.3 p/s
my spedometer and cruise quit working.
any answers
Old Jan 15, 2007 | 08:12 AM
95bogginbronco's Avatar
95bogginbronco
I worked at a ford dealer over the summer and encountered this problem a few times. I would say it is your speed sensor in your rear differential. It is a $13 part if i remember correctly. It is just one bolt, pull it out, lube the o-ring on the new one, and slide it in the hole, tighten it down. easy fix. I would try that first before I'd go crazy. It should fix the problem. While your at it if your truck had alot of miles on it and you haven't changed the gear oil you should do thzt too. Bad gear oil is hard on those sensors. Good luck
Old Jan 16, 2007 | 02:03 PM
trailertower
sorry, I tried a new sensor in rear end and speedo still does not work.
is there a ssor somelse?
Old Jan 16, 2007 | 06:46 PM
Franklin2's Avatar
Franklin2
May be a problem with the cluster. You may have to go to the dealer and let them hook their scanner up to it. I believe the speed signal goes to the speedo/cluster unit which has a micro-processor and processes the signal. This signal is then sent over a network in your truck, and is used by the engine/tranny computer as well as the cruise and the abs.
If the tranny is shifting fine, and you have no abs error lights, then it may be the cluster itself, but there is really no way of knowing without getting on the network and communicating with the truck.
Old Jan 16, 2007 | 08:29 PM
Wilber15's Avatar
Wilber15
The vss goes through the ABS module. check the fuses under the hood. Some may have been installed incorrectly at the plant. Check the 10 amp. red mini at the back left of the fuse box as your looking at it as well as a couple others. You might have some fuses that aren't even in their place. Check for any holes in the fuse box that have connectors but no fuses inserted. There's a TSB out for this. Don't remember if it went back to as far as 02' though.
