Sponsored by: Real Truck
05 binding and poping
Old Jan 15, 2007 | 09:00 PM
jitt's Avatar
jitt
I have an 05 4x4 SD thats binding and poping in the front end on hard turns. I initially thought it was the rear limited slip, but its in the front .....somewhere.
anybody got any ideas? Thanks.
Old Jan 15, 2007 | 09:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hi Jitt. Welcome to FTE!
It sounds like your front hubs are locked.
Unlock them and see if the noises and binding go away.
Old Jan 15, 2007 | 10:02 PM
jitt's Avatar
jitt
Unhappy
That was the second thing I checked. I've got ESOF and both hubs are in auto position. Thanks though.
Old Jan 15, 2007 | 10:05 PM
redford's Avatar
redford
OK, if your hubs are not locked then your hubs may be toast.
Old Jan 15, 2007 | 10:19 PM
jitt's Avatar
jitt
Sorta think its the u-joints on the axle shafts. Its hard to tell exactly where its coming from over the diesel rattle with your head under the front end.
Old Jan 15, 2007 | 10:25 PM
redford's Avatar
redford
Your front U-joints shouldn't move if your hubs are not engaged and your transfer case is in 2H.
Old Jan 15, 2007 | 10:38 PM
jitt's Avatar
jitt
It might very well be the hubs. But I would think it would bind and pop all the time instead of just during sharp turns.???? I guess I'll take it to the stealership in the am.
Old Jan 16, 2007 | 07:45 AM
redford's Avatar
redford
Jack up the front end. Rotate wheel and see if the driveshaft rotates.
Old Jan 16, 2007 | 05:27 PM
CHEEESEHEAD's Avatar
CHEEESEHEAD
I Get The Same Popping Noise When I Brake, Fwd Or Rev At Any Speed. What's Up With That?
