Heater F350
Heater F350
2004 F 350, diesel - so many posts, this might have been covered, if so bear with me. Heater problem, vehicle warms up, but when driveing off, will blow cold air, then blow hot and will cycle for some time before staying hot. Seems that when u stop it gets cold but as soon as u drive off again, gets hot
I just had a similar problem, i changed the tstat and flushed the radiator and also flushed the heater core seprately it kinda helped then i talked to a Frod service repa nd he told me that the heater core is probably blocked up, so i finally broke down and replaced the heater core and te peoblem is fixed. So what i am getting at is maybe you would want to flush the heater core it self and if that dosen't help well it's time for a heater core and with a little mechanical backround you can do it yourself it took me about 2hrs with a new rad flush.
baileymoeracing
01-04-2012 07:36 PM
joners
1997-2006 Expedition & Navigator
05-24-2010 06:07 PM
