Slipping Transmission
Old Jan 13, 2007 | 11:52 AM
jessie's Avatar
jessie
My Friend has a 1990 F-350 Diesel 4x4.
The Automatic transmission works well in 1st and reverse, If you go in drive it slips (takes awhile to get moving).If you manually shift from 1st to drive, 1st is strong, seems like no second and then into drive, fine.
My question is could this be computer problems or just mechanical?
Thank you,
BWard
2001 F-350 Diesel 4x4 Lariat CC LWB SRW
BTS Transmission/Chip, CCV mod, 6.0 trans.cooler,
4" Silverline exhaust, Cold Air Intake Modification, Autometer gauge's,
2006 Honda VTX 1300
Old Jan 13, 2007 | 12:29 PM
PLC7.3's Avatar
PLC7.3
We need to define whether this is a 3 speed C6 (special order) or the E4OD. What does the door label indicate under trans.
Old Jan 13, 2007 | 12:47 PM
jessie's Avatar
jessie
Thanks for the quick response,
On the sticker it has Trans-E
Is that the code we need?
Thank you,
BWard
2006 Honda VTX 1300
Old Jan 13, 2007 | 12:55 PM
PLC7.3's Avatar
PLC7.3
Yes that is the E4OD.... has he replaced anything on the IP like the TPS, on diesels it's called an FIPL. Does the Speedo and tack work flawlessy...... does the OD ON/OFF stalk light flash... Have you had major rain storms or has he been off roading.
Old Jan 13, 2007 | 02:26 PM
jessie's Avatar
jessie
What is FIPL?
Speedo seems to work good, Tach does not work at all.
OD Light stays on, it does Not flash.
It has done this since he bought it.
Old Jan 14, 2007 | 01:11 AM
PLC7.3's Avatar
PLC7.3
I hate to say this but your friend is operating in LIMP MODE second and reverse only..
This is a protective Mode the trans goes into to allow the vehicle to be moved from the highway to a safe place basically. NOT for everyday driving or you will burn up the trans..... if he has not already.
FIPL is Fuel Injection Pump Lever sensor.........
Fix the Tach sender on the oil filler housing....... or at least check the wiring.
The dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Old Jan 14, 2007 | 04:15 PM
jessie's Avatar
jessie
Thanks, We will try this.
Thanks again, I will let you know the status.
BWard
Old Jan 16, 2007 | 07:20 AM
jessie's Avatar
jessie
PLC7.3, I sent you a pm.
Thanks,
Brian
Old Jan 16, 2007 | 07:30 AM
knapikmichael's Avatar
knapikmichael
quick question what does it mean when the o/d light is blinking then it whines in reverse then it wont go foward at all
Old Jan 16, 2007 | 07:31 AM
knapikmichael
it took 4 months 4 it to stop goin foward since the light started blinking i was towing when this happened
