Turn off Check Engine Light
Old Jan 15, 2007 | 11:53 AM
kalvarad's Avatar
kalvarad
Question Turn off Check Engine Light
Just a quick question: How do I turn the check engine light off on an 02 Ranger after I make the necessary repairs?
Old Jan 15, 2007 | 11:55 AM
Madmike33's Avatar
Madmike33
Some codes need to be erased with and OBDII reader. You might also be able to reset by disconnecting your battery for about a minute.
Madmike33
Old Jan 15, 2007 | 03:04 PM
fordboy_52's Avatar
fordboy_52
Welcome to FTE kalvarad! Im glad you chose the best site on the net for ford trucks.
see you on the boards!
Matt
Old Jan 15, 2007 | 03:10 PM
freirefishing's Avatar
freirefishing
disconnect negative side of battery, for a minute...walmart has an odb2 reader for about 90 bucks, i got one last year, helps out, my check engine light came on, i read the code, saw that i needed a lower bank oxygen sensor, i ordered the part put it in myself got rid of the light and not spending money on someone diagnosing it, plus you can erase codes as well.
Old Jan 15, 2007 | 09:38 PM
jimdandy's Avatar
jimdandy
If you have cured the problem, the light will go off by itself in approx 3 start/stop cycles. jd
